Fuel pump relay
SCOTTEALS
  • 1991 DODGE CARAVAN
Electrical problem 6 cyl Front Wheel Drive Automatic 200, 00 miles
Dose anyone know where the fuel pump relay is on my 1991 dodge caravan (3.3 L V6)? I have looked on the drivers side fender and it is not there, I have called the dealer and ask them, they say it is on the firewall with one screw holding it on and gave me a part number, but I can not find that relay anywhere. It is not in the fuse panel ether. Please help I am pulling my hair out over here.
Friday, February 8th, 2008 AT 5:18 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
There is no fuel pump relay per say because it is control by the ASD relay located under the hood
Here is a wiring diagram notice the fuel pump in the right upper corner.
Here is a guide to help you test the relay
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Friday, May 12th, 2017 AT 6:36 PM
THETRINIDADS
  • 1998 DODGE CARAVAN
  • 4 CYL
  • 130,000 MILES
Electrical problem
1998 Dodge Caravan 4 cyl Two Wheel Drive Automatic 130000 miles
Where is it found and what does it look like>
Friday, May 12th, 2017 AT 7:04 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Under hood near battery in the fuse AND relay box
MOMMOMPOPPIE
  • 1996 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 245,678 MILES
Where is the fuel pump relay on the power distribution center on 1996 dodge caravan
ERNEST CLARK
  • 1,730 POSTS
Second from the bottom on the left.
CARADIODOC
  • 33,757 POSTS
Second from the end, next to the automatic shutdown relay. It's the middle of the three smaller relays.
Caradiodoc
