Dash BRAKE light
FATHEROF6
  • 2001 CHEVROLET MALIBU
  • 3.1L
  • 6 CYL
  • FWD
  • 96,000 MILES
My daughter's 2001 Malibu 3.1L has the dash brake light on. No codes, it just states DTC 00 I/M Yes
Do you
have the same problem?
Wednesday, January 20th, 2016 AT 7:59 AM
WRENCHTECH
  • EXPERT
That will come on for 3 different possible reasons.
1) parking brake applied
2) Imbalance in brake hydraulic system (noticeable pedal issues)
3) Low brake fluid
Wednesday, January 20th, 2016 AT 8:48 AM
FATHEROF6
I had actually checked brake fluid level after I submitted my question. Level was right at minimum level. I'm going to pick up some brake fluid and add it. I will let you know the result. Thanks for getting back to me.
Wednesday, January 20th, 2016 AT 9:07 AM
CARADIODOC
  • EXPERT
Excuse me for butting in, but simply adding brake fluid is definitely not the right fix. No conscientious mechanic will top off brake fluid during other routine services such as oil changes, and we often get faulted for that.
If the brake fluid is low, and indeed adding some might make the red "Brake" warning light go off, (you didn't specify if it's the red light or the yellow "ABS" light), you have to ask "where did it go?" It's possible there is a leak and that must be addressed, but much more commonly the front disc brake pads are near the end of their life and a brake system inspection is in order.
As brake pads wear, front or rear, the pistons move out of the calipers they're in to take up the gap. That is how all disc brakes self-adjust. Brake fluid fills in behind those pistons and is why the fluid level drops in the reservoir. Almost all calipers today are designed well enough that they usually don't need to be rebuilt or replaced during a routine maintenance brake job. Instead, those pistons just get pushed back into the calipers to make room for the new, thicker pads. Doing that pushes the brake fluid back up into the reservoir so the fluid level goes back up. If an inexperienced / untrained mechanic filled the fluid previously, it's going to run over and make a mess. Spilled brake fluid eats paint too.
When an experienced mechanic sees low brake fluid level, he looks more closely at the front pads, especially when they're easy to see through spoked wheels, and for signs of wetness around steel lines, rubber flex hoses, and rear wheel cylinders. If he has your best interest at heart, he will recommend a brake system inspection. He also knows there's a real good chance he will be accused of trying to sell unneeded parts and services, so he might just keep his mouth shut, let you drive until a worn pad starts grinding on a rotor, and then you will spend more money when new rotors are needed. He won't be blamed, but it ends up costing you more in the long run.
Now that I've added my piece, I'll let you guys back to your conversation.
Wednesday, January 20th, 2016 AT 10:38 AM
WRENCHTECH
  • EXPERT
He's right, if the fluid is low, the pads should be checked for wear and the system for any leaks.
Wednesday, January 20th, 2016 AT 10:58 AM
FATHEROF6
I will have them checked pronto. Thanks to you both
Wednesday, January 20th, 2016 AT 3:22 PM
Recommended Guides
