Cranks and has started, sat for a year for a pinion, bearings etc. Shoted front drive shaft. Note all wheel drive. Drove 80 miles at 55mph, has stiff off road suspension and 44 inch tires, minus wheel wells. Easy to roll under to work on. Throttle has been removed and returned, tps and map removed and cleaned, looked good. The hose off air intake going to valve covers, dont know what part it attached to was completely clogged. Cleaned out, started idled, then shut down. Looks like some rat bites in some hoses, kinda dirty even after low pressure water cleaning. Rat bites dont look all the way through. CPS 3 wire connection lock is broken, I unplugged and plugged it cranked idle, then shut down, crank only now. No spark in between no crank. Unplugged and plugged cps, crank no start. Still no check engine codes except mentioned above. Cant see cps plate underneath.
I cant do much, I have cancer JEEPS on gravel, I put plywood down and have a roller. My arms aren't stronger enough to hold them up under, cant see where the sensor enters. Could it be something else and why why why no codes. No check engine. You guys do great work havent seen such good advise ever on any other appliances. Thsnk you, , im your best live ad.
Wednesday, January 21st, 2026 AT 7:28 PM
