Power lost to power port and cigarette lighter?
YYANG53
  • 2004 HONDA ACCORD
  • 6 CYL
  • FWD
  • 20,000 MILES
I was plugging into the cigarette lighter to get power for my iPod when the LED indicator suddenly dimmed off---no more power access but the car starts, drives and the CD/radio plays OK. Hmmm. There was no UFO around. What could be wrong? Thanks a lot!
Friday, December 26th, 2008 AT 9:42 PM
BMRFIXIT
  • 19,053 POSTS
There is a power accessory relay and fuse #9 15 amp in the kick panel fuse panel, here are two guides to help test and the fuse and relay location as well
and
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Friday, December 26th, 2008 AT 11:45 PM
JOHNS2
I had to replace the relay everything works again! Thanks for the guides they really help.
Wednesday, October 14th, 2020 AT 11:49 AM
YAM
  • 23 POSTS
  • 2001 HONDA ACCORD
  • 4 CYL
  • 104,000 MILES
I have recently purchased a used 2001 honda accord, and found only one problem with it, is that the cigarette lighter outlet is very loose and I have been searching online to try and find the part for this to get it fixed, but can not seem to track this down, any advice to were I can either get an OEM part or generic that would fit, and also what would be the part number on this? Very confused and very hard to find online! Thanks for any help anyone can give!
Wednesday, October 14th, 2020 AT 11:50 AM (Merged)
EEBOTE
I always call the dealer customer service when I ran into problem locating parts from local auto parts store. Most of the time the dealer has the parts you are looking for for a special order. Hope this helps.
JUSTIN RYAN
  • 1997 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • 192,000 MILES
Radio and cigarette lighter run on the same fuse. My issue is the radio works but my cigarette lighter does not. If they run on the same circuit should they both be working or not working?
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The cigarette lighter could have a bad wire or ground. Use a voltmeter or 12 volt test light and check for voltage. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
209WHITEBOY95207
  • 1997 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • 150,000 MILES
I finally read something in a post that you addressed for someone else that made me realize I'm in the company of someone who understands what is wrong. My car listed above coupe 2.2l 4 cylinder sohc is the vehicle. Have an aftermarket deck, all fuses under hood and drivers side by hood release good. What should I be looking for/trying to track down here to fix this?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
There are a few things to look for. Being an aftermarket deck sometimes they have a blade style fuse located in the rear of the deck housing. Also, most aftermarket decks come with inline fuses within the aftermarket wiring harness usually in the red (positive) wire. I will look for a photo reference to attach. Can you tell me what brand aftermarket deck it is? Hope this helps and thanks for using 2CarPros.
209WHITEBOY95207
Hi Danny, thanks for the reply. I already checked the blade fuse at back of deck, verified that it was good (even replaced with a new one just to be sure) and though you are correct and I'm familiar with most having an in-line additional tube style fuse that runs with the positive input wire, my deck does not have one. It is a JVC with Bluetooth plus aux and USB input options, don't recall the exact model number off hand. Ran a 12v power wire from the battery and pushed it into the positive. Corresponding wire lead to the deck and it turned on and works normally if that helps any?
DANNY L
  • 5,648 POSTS
Hello again.
So the radio works and you are now looking to fix cigarette lighter?
Danny-
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,086 POSTS
There is a cigarette light power relay that needs to be checked. here is a guide to help you with the relay location:
Check out the diagrams (below). Please run this test and get back to us.
