1995 Chevy Silverado truck dies when shift into any gear li
ARTHURDMAX
  • 1995 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 200,000 MILES
Truck had tune up had 44k or k44 run thru to clean out engine, was told dont think its the fuel pump, but it dies when shifted must keep foot on the gas pedal at all times. If have any ideas let me know
Do you
have the same problem?
Saturday, July 17th, 2010 AT 6:54 PM
CHEVY57350
I am currently having the same problem with the same model truck. I have cleaned out the throttle body entirely and put new gaskets. I replaced the throttle position sensor, and I still have that problem. Also changed the fuel filter. My pump is running fine. I have no clue so far, but I guess I'll let you know if I figure it out.
Wednesday, July 21st, 2010 AT 9:56 PM
CHEVY57350
I'm going to try the map sensor next, and if that doesn't work, I'll try the ECM. I'm hoping the map sensor works. You can test to see if you need to replace any of these, but I can't because I don't have the equipment. I'll let you know if the map sensor works tomorrow.
Thursday, July 22nd, 2010 AT 8:21 PM
OMALEY29
I have a 1990 Chevy silverado K1500 4x4 with 350 tbi. I have same problem its runs rough but stalls out in any gear. I have changed
Idle air control
Throttle posit sensor
Egr
Plugs wires cap rotor
Fuel pump and sending unit(forgot about ground and broke it)
Fuel filter
Fuel injector and fuel pressure regulator
Bought new Map sensor today lets pray. Also bought a good digital multimeter star testing connectors.
DID YOU EVER FIX YOURS?
Thursday, August 5th, 2010 AT 2:01 AM
WA
Same issue here what did your problem end up being? I have changed the TPS sensor, injectors, fuel regulator, plugs, wires, cap, rotor, coil, runs/idles strong but then put into gear and it stalls out. Any ideas would be great thanks. 1990 Chevy Silverado 350 V8 5.0L
Monday, May 23rd, 2011 AT 4:11 AM
EARL17
Hello this is the exact problem with my brothers 1995 Chevy k 1500 extended cab did anyone ever find out that the problem was if so please let me know its driving me crazy not being able to fix it.
Monday, August 11th, 2014 AT 11:09 PM
Recommended Guides
