No starter operation?
DWALLSMD
  • 1993 CHEVROLET SILVERADO
I have a 1993 chevy z71 extended cab with a 5.7 350 in it the truck will not start the battery is good I replaced the starter and cilinoid it still wont turn over the truck has 133,000 miles on it
Thursday, November 15th, 2007 AT 8:27 AM
JAMIE CLETCHER
Check and make sure the activation wire to the selinoid is getting voltage from the ignition switch to the selinoid. check and make sure there is not a fusible link that might be bad in the activation wire. On some models there is a fusible link under the relay cover on the passenger side firewall, check that also. This guide can help us fix it
Saturday, November 24th, 2007 AT 5:32 PM
REAP88
Electrical problem
1993 Chevy Silverado V8 Automatic
my truck has been sitting for 3yrs I changed battery, checked my fuses, pulled my starter had that tested its good. When I go to start it I get nothing. Not a click or anything my dashlights work.I cut my d.L.C.(Data link connector)out to use elsewhere. That wouldnt have no effect would it?I live in the mountains so taking it to the shop is out. Any help?Thank you 2carpros!
Thursday, September 3rd, 2020 AT 5:21 PM (Merged)
Hold the key at cranking position and check for power at the starter solenoid small terminal with a pruple wire if there's no power -check the purple wire if its open to the ignition switch-NOTE: You do not have a NSS/Park and Neutral switch. Its from the ignition switch straight to the starter
https://www.2carpros.com/forum/automotive_pictures/12900_st1_36.jpg
REAP88
Electrical problem
1993 Chevy Silverado V8 Two Wheel Drive Automatic
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Hi, It sounds like your battery cables might be the problem. Using a test light test for 12 volts at the starter. If you power is present replace the cable(s) Also, check the fusible links down at the starter to make sure they are intact. Thanks for using 2carpros. Com
GREG93POS
  • 6 CYL
  • 236,000 MILES
93 chevy silverado intermittent no crank. Sometimes starts just fine other times nothing. I have a good battery dash lights are on and don't dim when I turn the key. Do need to pull the steering wheel and check the ignition switch?
Your probable causes here could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
ZEE.EZ.TUNER
  • 1992 CHEVROLET SILVERADO
Engine Mechanical problem
1992 Chevy Silverado V8 Four Wheel Drive Automatic
Dear Car Pros
After starting my truck and running it for only a short time (2 min), two weeks ago, it has gone belly up
My truck's engine won't turn over or fire on gasoline being added to the carborator. I've checked the distributing caps and wires made sure nothing was torn or wet. I live in a wet environment and think that some other connection isn't being made. Do you have any suggestions on where to look next?
Thursday, September 3rd, 2020 AT 5:22 PM (Merged)
RHALL77
  • 3,361 POSTS
You said it wont turn over. Did you check the battery connections. Are you sure the battery is good.
ZEE.EZ.TUNER
I ended up filling one of the battery portals and jump starting the engine that way. Thanks for the tip on checking the bat. I has started beautifully since I broke off the obstructions to the connections.
AMISHRON
  • 130,000 MILES
There is a red wire going to the junction box on the firewall on the passenger side that burnt completely in two while trying to start the engine. Where does this red wire go to & what is causing this wire to get hot only in the start mode?
Thursday, September 3rd, 2020 AT 5:23 PM (Merged)
  • 108,192 POSTS
These wires burn when they get melted by the exhaust manifold on the right side. You will need to replace the fusible links at the starter as well. I know because it happened to my truck I have the same thing.
AMISHRON
Yep you guys are so good you hit it on the money, I got the parts to fix it and the starter had to come out but I got it fixed up. I love this site thanks again ;)
ADAMHARVELL
  • V8
  • 205,000 MILES
I have a 92' chevy silverado 1500 that does'nt start sometimes. It will make a "click" noise when I turn the key, and another "click" when I release. It only happens sometimes, and if I keep on turning and releaseing the key it will eventually start. Do I need a starter?
SATURNTECH9
  • 30,870 POSTS
If it's the starter clicking then there's a good chance it could be the starter.I would have the battery tested and make sure the battery cable's are clean and tight.Also do you have a multimeter or test light to do some testing when it act's up so we can see if it's the starter?
ADAMHARVELL
The battery is new and fully charged, the cable connections are clean and tight. I do have a multimeter, but I'm not 100% on how to use it. At first the truck was starting more than not starting. Now the problem has gotten worse. It may start first try sometimes but when it fails, it makes a kinda loud click noise (sounds like its coming from the starter) and a lesser click noise when I release the key from the crank position.
SATURNTECH9
  • 30,870 POSTS
Since your not sure how to use the multimeter do you have a test light?Those are really easy to use. Let me know it sound's like a bad starter though I just want to be sure. Also make sure the positive battery cable to the starter is clean and tight. Make sure you check that with the negative cable unhooked from the battery. If you have a test hook the aligator clip to a ground when it doesn't start and see if you have power to the purple wire at the starter with the key in the start position. If you do bad starter. If we use the multimeter the black lead goes to the common connection on the meter and the red lead goes to the V connection on the meter. Then set the meter to 20 DC volts then ground the black lead and use the red lead to test for battery voltage at the starter purple wire with the key in the start position if you have battery voltage and the starter is inop bad starter. Let me know what you find.
CEROZOOL
  • 5.7L
  • V8
  • RWD
  • 217 MILES
The truck quit running and would not start up. Spark quickly arose from the terminals an battery. I fixed the wiring. And when I went to put it back negative went first. Then positive, smoke started again to rise from the terminals.
WRENCHTECH
  • 20,757 POSTS
It sounds like you had a fusible link burn out, probably due to a short somewhere else in the truck. If you burned out a fusible link and replaced it with regular wire, that is a big no no and can cause a fire or severe damage to the car. You need to find the short and repair it first and then replace the wire section with fuse wire.
HOFLAK
  • V8
  • 150,000 MILES
The truck doesn't crank over. The battery is new. The fuses look ok. What do you think the problem is?
