1995 Chevy Lumina Bypassed the AC and now my car overheats.
MICHEAL23
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 135,000 MILES
My A/C clutch/pulley was making a high whining noise so I figured it was about to go out so instead of spending 100+ dollars to put on a new compressor, I measured the serpentine belt to where I could bypass it, I did. And now (after double checking the belt route, ) My car overheats real bad. Could I have reversed the water pump by any chance?
Do you
have the same problem?
Friday, December 28th, 2007 AT 6:23 PM
SERVICE WRITER
  • EXPERT
IF it is overheating now and wasn't before the by-pass it sure sounds like a mis-routing or slippage.
Are you working off
a diagram to check it?
I don't think you can by-pass it like that.
The belt is not going to touch the water pump enough or if you wrapo it around it will spin the wrong direction.
http://www.2carpros.com/forum/automotive_pictures/30961_31_1.jpg
3.1?
Friday, December 28th, 2007 AT 6:27 PM
Recommended Guides
