Blower motor installation
ROBET LAWSON
  • 2004 CHEVROLET CAVALIER
How do I install a blower motor on this car?
Friday, November 14th, 2008 AT 7:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Removal:
Disconnect the electrical connections from the blower motor.
Remove the blower motor retaining heat stakes with a chisel or a screwdriver.
Remove the blower motor .
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528005d5b6_2.jpg
Note:
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Installation:
Install the blower motor screws and tighten the screws to 44 lb inches (5 Nm).
Connect the blower motor electrical connector.
Friday, November 14th, 2008 AT 11:57 PM
STEVE987
  • 2003 CHEVROLET CAVALIER
Four cylinder front wheel drive manual.
I am trying to remove the blower motor, but there does not seem to be any nuts or bolts holding it up under the dash. Where you would expect nuts or bolts to be, there are plastic covers that are not removable that have a small (about 7 mm) hole in the center. I cannot see inside the hole. How do you remove the blower motor?
Thanks!
Monday, July 2nd, 2018 AT 2:45 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Hello, here is a guide to show you what you are in for when doing the job with diagrams below that show you how to remove blower motor on your car. Should be 7mm screws.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Cheers
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_cavalier_blower_motor_1.jpg
My parts book showed the above picture. The two holes around the edge are probably for the retainers, may be a third one on the opposite side of squirrel cage, that we cannot see in the picture? My information says to remove the retainers with a chisel or screwdriver. I do not have an actual picture of retainer, you need to be sure.
Monday, July 2nd, 2018 AT 2:46 PM (Merged)
BOBJRNC
I am trying to remove my blower motor for replacement. It looks as though there is a housing with rivets keeping me from dropping the blower motor itself. I have attached a picture. I need to know next steps to either remove these rivets or am I missing something altogether.
https://www.2carpros.com/forum/automotive_pictures/515577_IMAG0002_1.jpg
Wednesday, April 3rd, 2019 AT 10:51 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Those are heat stakes and you have to use a chisel to cut them out. purchase new fasteners for installing new blower motor. Here is a guide and diagrams below to show you how on your car.
I 4 CHEVY
  • 10 POSTS
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 182,000 MILES
I own a 1998 Chevy Cavalier. My fan went down to one speed and then quit. I took out the blower motor and gave it some power and it worked. I was told the resister was bad so I replaced the resistor. After replacing the resistor I got heat and air out of my duct for a day. Then the blower motor quit with no air coming out of my duct. Before it quit all the fan speeds were working and all air positions were working as well and I did have heat. Don't know what is wrong relay, switches etc. I am wondering what is or very well could be wrong. If it is relay were is it and how do I test it or switches or anything else to see if they are bad? Any help would be great.
Check the blower fuse 30amp if okay-test the blower motor relay in the engine compartment fuse/relay center
I 4 CHEVY
  • 10 POSTS
Thank you. How do you test relay
By using an ohmmeter to check the coil and switch side of the relay unable to do it-swap or replace the relay
I 4 CHEVY
  • 10 POSTS
I replaced the relay and I still get nothing.
Check the AC/Heater control switch input power-not it could be coming from the HVAC control module-
I 4 CHEVY
  • 10 POSTS
The control switch is the one on the front of the dash used to contorl the speed and the other the direction of air flow correct? Just wanted to make sure we were talking about the same one.
I 4 CHEVY
  • 10 POSTS
How to test control switch? What readings should I be looking for on the meter?
I 4 CHEVY
  • 10 POSTS
Does anyone know how to test the AC/ Heater control switch input power and what readings I should be looking for on the meter?
BLUELIGHTNIN6
  • 16,542 POSTS
Test the blower switch with a test light.
Connect test light between blower switch connector terminal "E" (Black wire) and battery voltage. If test light illuminates, blower switch needs replaced. If test light does not illuminate, there is probably faulty wiring that needs to be traced with the test light.
I 4 CHEVY
  • 10 POSTS
Thank you. Did you happen to see my origional question? If so, what else do you think could be the problem?
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, I did read it.
I did not mean to interrupt between you and Rasmataz, as he is a great tech. I simply stepped in because I am sure he is busy and could not get back to you yet.
Between what you two have already tested out and talked about, I would assume it has to lie somewhere in the switch or in the wiring.
I hope this helps.
Just post results of light test and either I or Rasmataz will follow up.
I 4 CHEVY
  • 10 POSTS
I don't mind you stepping in at all. I need all the help I can get. It is about to get cold and snowy here so I need some heat not so much for me but so I can see out my windows. It seems like all the stuff I try just doesn't fix it. I will test the switch and let both of you know what I come up with. Again thank you for your help.
2CP-ARCHIVES
  • 4,540 POSTS
  • 1996 CHEVROLET CAVALIER
  • 180,000 MILES
How to replace the heater fan
