Power window motor
PASHMORE6
  • 2002 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 115,000 MILES
How do I replace the power window motor on rear driver side?
Monday, August 2nd, 2010 AT 9:11 PM
HMAC300
  • 48,601 POSTS
Here is a guide that will walk you through the etps with instructions in the diagrams below to help you on your car.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Tuesday, August 3rd, 2010 AT 10:51 AM
LINDA1629
  • 4 CYL
  • FWD
  • 100,000 MILES
Can you please tell me how much you think it would be to replace the passengers window motor/regulator. The window does not budge when you want to close it. Thanks a bunch.
Thursday, April 16th, 2020 AT 11:45 AM (Merged)
BUZZSAW
  • 1,198 POSTS
2-300 bucks
AJDEFOE
  • 2000 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 10,300 MILES
The front driver-side power window motor is in need of replacement. I can see that it is riveted on and I can drill those out. My problem is where the regulator (scissor-type) and motor attach: I have read that there is a spring mechanism that needs to be dealt with using a special tool. How do I detach the regulator from the motor safely and then attach a new motor correctly?
MERLIN2021
  • 17,250 POSTS
WINDOW MOTOR Removal & Installation 1. Pull inside door handle to full open position. Push in on door handle pull cup, while prying out at top with flat-blade tool. Pull up on door handle pull cup to remove. 2. On front doors of hardtop models, remove power door lock switch and power window switch. See WINDOW & DOOR LOCK SWITCHES . 3. On front doors of convertible models, remove power door lock switch. See WINDOW & DOOR LOCK SWITCHES . 4. On all models, remove upper trim finish panel. Remove door trim panel lower screws. Remove door armrest. Remove door panel and set aside. 5. Remove water deflector enough to access motor/actuator assembly. Disconnect motor/actuator assembly electrical connector. Remove motor/actuator assembly bolts. Remove motor/actuator assembly. 6. To install, reverse removal procedure. Tighten motor/actuator bolts to 53 INCH lbs. (6 N.m). Page 1 of 1 POWER WINDOWS -2000 Chevrolet Cavalier 4/24/2009
Not on this one. More info here:
https://www.2carpros.com/how_to/power_window.htm
Convertibles do have a spring mechanism.
AJDEFOE
Thanks for the reply, but you did not address the spring issue. Where exactly is this spring and how do I keep it from releasing when I disconnect the motor from regulator? I want to replace just the motor, not the regulator too. Also, the first link you posted did not work.
MERLIN2021
  • 17,250 POSTS
I thought I did address the spring, non in yours! The directions are specific to your car. The first link is dead, it only shows where I got the info! You do NOT need to remove the regulator on yours. You do have to remove the regulator because it has a coiled spring on convertibles.
KATML91
  • 150,000 MILES
The motors in my windows are bad. They are the original motors for my car. About two months ago we tried to get the motors out to replace them with new ones, but the old motors are stuck to the gears. Any suggestions as to how I can get the old motors out to replace them with the new ones?
HMAC300
  • 48,601 POSTS
They are replaced as an assembly meaning motor and regulators. I think they are available online for around $60 each dorman makes them.
KATML91
Thank you so much! You actually responded to two of my questions on here. I am going to give both a try. It will save me from having to find a way to get a whole new car, especially with the other question about the fuel lines. I appreciate it. :)
4005SIW
  • 1999 CHEVROLET CAVALIER
  • 100,000 MILES
Is there a procedure you could send me an attachment of? Can get a used motor for $40 and haven't found a good labor price in zip 48912.
Thursday, April 16th, 2020 AT 11:46 AM (Merged)
WINDOW MOTOR
On front doors of hardtop models, remove power door lock switch and power window switch. On front doors of convertible models, remove power door lock switch. See WINDOW
CADIEMAN
  • 3,544 POSTS
How do u know its the motor?
4005SIW
Not sure it's the motor yet. Just beginning on this.
CADIEMAN
  • 3,544 POSTS
Hold the switch to go down. Then bang on the panel. If the motor turns on youll know its the motor.
FIXITMR
  • 9,990 POSTS
Motors dont go bad much but overheat sensors do. You can dissasemble motor and bypass sensor and it should work again.
ERIC1980.EB
  • 4 CYL
  • FWD
  • MANUAL
  • 146,000 MILES
Can someone tell me what exactly I need to replace in my power window motor on my cavalier trying to rebuild it and even after getting new brushes for it and installing them still weak and not enough power to move the regulator very much at one time? Could it be the spindle or magnet? Any pointers will help. Thank you. P.S. I have tested everything and did replace the switch cause the other side was not working and it was the switches and now the drivers side still isn't working, at my wits end with this. Time to buy a new motor or is it possible to make it work?
SATURNTECH9
  • 30,870 POSTS
I have never tried rebuilding a motor there reasonable to buy a rebuilt one try www. Rock. Com or amazon for a better price on one then the auto parts store.I would just replace it if its not the brushes then you have a stator or magnet issue.
CARADIODOC
  • 33,742 POSTS
Look for a thermal cutout inside the motor. I think they're a glass bulb with a set of contacts, but Wrenchtech mentioned some other device that I can't remember. The contacts in those glass bulbs become pitted and add resistance to the electrical circuit. They cause more problems than they prevent. You can prove it by temporarily bypassing it with a jumper wire. They do that on a regular basis at one local used car dealership, but I would never recommend doing that on a permanent basis. Lawyers and insurance investigators love to find modifications that could lead to problems.
ERIC1980.EB
Awesome all is helpful! I will take that son of a gun back apart and look to see if I can find what you are talking about and if not well guess I'm going to rock. Com thanks guys!
