2000 Chevy Blazer
LOS188
  • 2000 CHEVROLET BLAZER
Air Conditioning problem
2000 Chevy Blazer 6 cyl Four Wheel Drive
how to add refrigerant to system
Do you
have the same problem?
Sunday, September 12th, 2010 AT 2:31 PM
MADMIKE1735
  • EXPERT
Without a bottle of r-134a, and a set of manifold gauges, its cheaper to bring it to a garage, and let them evac, and recharge to proper pressure. They will set a vacuum which removes all moisture from the system, and then drain old oil, and replace with new pag oil, and also a UV dye. They also charge your system to manufacture specifications. Its worth the money.
Friday, September 24th, 2010 AT 8:56 PM
Recommended Guides
