I can't find the knock sensors I know they should be under the head but I don't see them
Wednesday, January 20th, 2010 AT 5:48 PM
BLUELIGHTNIN6
MECHANIC
The knock sensor (KS, only one of them) for the 4.3L engine is located on the top rear of engine, pic below..
SPONSORED LINKS
Thursday, June 15th, 2017 AT 12:37 PM
CQUELETTE
MEMBER
1 POST
2001 CHEVROLET BLAZER
6 CYL
2WD
MANUAL
130,000 MILES
My knock sensor is throwing a check engine light and I have no idea where it is located. Can you help
Friday, January 29th, 2021 AT 10:30 AM
(Merged)
MECHANIC
(Merged)
R. DRAIN
MEMBER
1 POST
2000 CHEVROLET BLAZER
Engine Mechanical problem 6 cyl Four Wheel Drive Automatic 104, 00 miles
I need the location of the knock sensor can you please tell me?
Friday, January 29th, 2021 AT 10:31 AM
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
The knock sensor is located at the rear of the block near the firewall at the transmission flange. Here is a diagram (below) to help you see where it is. Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
(Merged)
GFUNARO
MEMBER
1 POST
1998 CHEVROLET BLAZER
I am trying to locate the knock sensors for a 98 chevy blazer with a v6 engine. I cannot find them anywhere! I looked all over the block and around the starter. The book says " located in engine block. One under left bank cylinder head, and one under right bank cylinder head." Please help.
(Merged)
MIKEYBDMAN
MECHANIC
No wonder. Approach the engine from the left side, and look under the distributer. It appears to be located just forward of the transmission bellhousing, and just on the left side of top of the engine block. It is aft of the left head, and almost looks like it is right on the flange of the engine to tranny mount.
(Merged)
MIKE420
MEMBER
1997 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
175,000 MILES
Where is the knock sensor located?
(Merged)
DOCHAGERTY
MECHANIC
At the top rear of the engine, behind/below distributor.
See the guide below for an idea of what you are in for
Vehicle specific instructions/diagrams are attached below
Images (Click to make bigger)
(Merged)
REPAIRMAN1
MEMBER
1 POST
1996 CHEVROLET BLAZER
1996 Chevy Blazer 4.3L 6 cyl Four Wheel Drive Automatic
Where Will I Find The Knock Sensor?
(Merged)
JDL
MECHANIC
Looks like rear of engine, two wire connector.
(Merged)
KNOCK SENSOR
MEMBER
1 POST
1994 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
123,000 MILES
I went to auto zone to put have my blazer checked for my :engine soon light was on: the gentlemen read three codes 1 egr was bad then my knock sensor was bad but as im driving ive never heard knocking is there something else im missing? I need help ty
SPONSORED LINKS
Friday, January 29th, 2021 AT 10:32 AM
(Merged)
BLACKOP555
MECHANIC
Can you get the exact codes for me? They may not be bad.
A knock sensor is a piezo type sensor that senses engine detonation and then changes ignition timing to prevent damage to the cylinders.
You wont hear a knocking sound necessarly, probably only when going up a steep hill.
(Merged)
JSPEED76
MEMBER
Engine Performance problem
1994 Chevy Blazer 6 cyl Four Wheel Drive Automatic 135xxx miles
where are the knock sensors located at on my blazer? I was told just above the oil pan on either side, is this correct?
(Merged)
MERLIN2021
MECHANIC
I will assume if it's a six, it's an s10 blazer? There are several location depending on your VIN here's the list.
K1500 full size is different!
At J1 and J2
(Merged)
JSPEED76
MEMBER
It is a 1994 s10 blazer tahoe lt 4.3 vortech. The diagram you put up looks right, I def have one where J2 is but I can't seem to find the other one. And is there anything I should know about the replacement?
(Merged)
MERLIN2021
MECHANIC
Do you have a scan tool that reads sensor data? If yes, start the truck, attache scanner, tap on head near the knock sensor, look for change in the way the graph or line representing the sensor looks, also check for timing to retard a bit when you tap, if these happen, the sensor is OK! As far as location I only posted what I found, havent replaced too many of them!
(Merged)
SHAWN BROWN
MEMBER
1 POST
I have a 1996 Chevy blazer 4wheel drive 2door where is my knock sensor located at can some send a picture of it please. And is it easy to change my self. Please help
(Merged)
STEVE W.
MECHANIC
It's on the rear of the engine, Screws into the block between the distributor and the drivers side cylinder head. Very easy to replace BUT how have you tested it to be sure it's faulty and not the wiring? Code?
