The starter Bendix/solenoid is most likely bad and preventing the starter from engaging with the engine flywheel. Is suspect you should replace the starter.
Here is a link that explains how a starter works:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Here is a link that shows in general how one is replaced:
Here are the directions specific to your vehicle for replacement. The attached pics correlate with the directions. Make sure before you begin working the battery is disconnected.
_______________________________________
2004 Chevrolet Malibu L4-2.2L VIN F
Procedures
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures
PROCEDURES
STARTER MOTOR REPLACEMENT
REMOVAL PROCEDURE
IMPORTANT: Record all pre-set radio stations.
pic 1
1. Turn the ignition OFF.
2. Disconnect the negative battery cable.
3. Remove the B+ battery cable nut at the starter.
4. Remove the S-terminal nut.
pic 2
5. Remove the lower starter assembly to engine block bolt.
6. Remove the upper starter assembly to engine block bolt.
7. Move the starter right, clearing the engine block, then left and out of the engine block (flywheel housing).
INSTALLATION PROCEDURE
pic 3
1. Guide the starter into the engine block (flywheel housing).
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the starter mounting bolts.
Tighten
Tighten the starter to engine bolts to 40 N.m (30 lb ft).
3. Install the B+ cable and nut.
Tighten
Tighten the B+ cable to starter nut to 10 N.m (7 lb ft).
4. Install the S-terminal wire and nut.
Tighten
Tighten the S-terminal nut to 5 N.m (4 lb ft).
5. Connect the negative battery cable to the battery.
__________________________________________________________
Let me know if that helps or if you have other questions.
Images (Click to enlarge)
Jan 29, 2021 at 1:56 AM
(Merged)
