Wont crank
KENNY DERRINGER
  • 2012 VOLKSWAGEN JETTA
  • 2.5L
  • 5 CYL
  • FWD
  • 110,000 MILES
When you push starter button it just clicks and dash lights flash, new battery and good starter, all other electronics work fine.
Wednesday, November 30th, 2016 AT 2:23 PM
JOHNNY G.JR
  • 320 POSTS
Security system might be enabled,try resetting it.
These two guides should help us
https://www.2carpros.com/articles/how-to-reset-a-security-system
and
Monday, October 23rd, 2017 AT 6:21 PM
KENNY DERRINGER
How would I do that?
JOHNNY G.JR
  • 320 POSTS
Pulling fuse, not sure how long.
JOHNNY G.JR
  • 320 POSTS
Check home page here scroll down to security, click on.
SATURNTECH9
  • 30,869 POSTS
The security system would not do that on that car. Sounds like you have corrosion or a bad connection/loose connection.
JAMESHOLMES
  • 2008 VOLKSWAGEN JETTA
  • 80,000 MILES
I have a 08 jetta s 2.5l. When you turn the key I have no power it wont crank at all I replaced the ignition switch and still the problem persists Im not getting any codes I replaced the fuel pump and the car started just fine but the next day it would not crank like the key has no power the head lights come on and I have the DRL light on on the dash but no other lights
Monday, January 6th, 2020 AT 12:47 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
It sounds like you have a bad starter motor. We need to check the trigger wire at the starter to see if it is getting power while in the crank position. Check out this guide toward the bottom to see how to test the starter
and if the starter tests bad this guide will give you an idea of what it will take to fix it.
You will need to raise the car up safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here are some diagrams to show you how on your car. (below)
Cheers, Ken
BIGGYFEET
  • 2006 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • 132,000 MILES
Wont start battery is good fuses are good all lights turn on. No turn over clicking sounds.
  • 31,937 POSTS
It sound like the starter contacts are not connecting. I would confirm the failure by using a test light on the starter trigger wire (small) if you have power the starter is no good here is a guide to help you see what you are in for when doing the job.
Check out the diagrams (Below). Please let us know what you find.
Cheers
BLAIRFAMILY
  • 2003 VOLKSWAGEN JETTA
  • 4 CYL
  • MANUAL
  • 84,000 MILES
I went to crank the car, and there was no response. Then, after trying a few more times, the car's blinkers and wipers began to function irratically. I' trying to diagnose the problem and I'm not sure where to begin?
STEVEW84
  • 673 POSTS
If the car is not cranking over then you need to see if you are getting power to your starter when you are trying to crank your vehicle. Also check your battery, cables, and connections.
SUMOAU
  • 93,000 MILES
I drive a TDI. Have been having problems getting it to start when it's cold out, especially when it's in the low 30's in the morning. It can take me up to 40 times turning the key to get it to start. When it's not as cold, can take me up to 2 to 6 tries. The radio comes on, and the vent, when I turn the key, but the car does not turn over (no crank). I have turned the key so that the radio is on for a minute, and then try to start again, per someone's suggestion, but have not had luck with that. I had the battery replaced, mechanic said the glow plug is fine. He thought it was the ignition switch, but when I brought it in, he said the battery cable main Terminal 30 wire was loose, tightened, load tested charging system OK, and not other electrical issues were detected, but the next morning I had the same problem again. When I leave the car in the garage, I have no problem starting it. After I have started the car in the morning when it's cold, I have no problem getting it to start for the rest of the day. I bring it in for regular oil changes, just had the R&R intake manifold cleaned out with new interior filters because of sluggish performance.
F4I_GUY
  • 3,302 POSTS
If it does not crank, do not waste your time looking at the glow plugs or intake manifold.
On your vehicle a very common problem is that the ignition switch overheats and melts the wires/connector underneath the steering wheel.
Another common issue is that the starter solenoid wire sometimes breaks or has a loose contact. When the vehicle does not crank, I would remove the solenoid signal connector and test to see if you have proper voltage there.
CATBRO
  • 2000 VOLKSWAGEN JETTA
  • 6 CYL
  • AWD
  • MANUAL
  • 134,000 MILES
My engine will turn over and start but dies after 5 mins of driving and there is a cloud of white smoke coming out of my tail pipe. What would be the problem?
Cloud of white smoke, if its not due to condensation from a cold start could be coolant leaking into the cylinders.
Get it block and pressure tested to find out more.
JACOBBELTON
  • 2001 VOLKSWAGEN JETTA
  • 6 CYL
  • 200,000 MILES
I enyered my car ready for work and the alarm sounded. After turning off the alarm I tried starting the car. Nothing. The radio and all the other electronics work but the car will not turn over. Kike there is some evil kill switch. Please help
F4I_GUY
  • 3,302 POSTS
Do you have an aftermarket alarm or factory alarm?
If its factory, close all the doors, lock then un lock the vehicle. And try starting it
