Engine Performance problem
1992 Cadillac Deville V8 Two Wheel Drive Automatic
i replaced the fuel filter and now the car wont even start. It will turn over but thats it. Could someone please help!
Sunday, December 7th, 2008 AT 10:38 AM
MECHANIC
Are you getting fuel pressure? When replacing the filter, did you place fuel flow in the right direction? Are you getting spark to the plugs?
Let me know. If you check fuel pressure, try it after the filter.
Sunday, December 7th, 2008 AT 7:59 PM
ROCKINFELLER
MEMBER
Thanks for all the help the fuel filter was located under the front on the passenger side. The total problem was ign. Module that was bad. Thanks for all the help greatly appreciated
