Where is the cabin air filter located?
CLINTON SAMUELS
  • 2004 CADILLAC ESCALADE EXT
  • 6.0L
  • V8
  • 4WD
  • 99,000 MILES
No access as described by videos.
Saturday, May 24th, 2025 AT 4:15 AM
CANNON1349
  • 864 POSTS
Hello, this vehicle does not/should not have a cabin air filter. Here is what comes up from the repair software:
This Article has been updated by bulletin #PIT3330, dated December 22, 2004.
Condition/Concern:
A customer may inquire about the availability of the passenger compartment air filter.
Recommendation/Instructions:
Starting in 2003 model year, the passenger compartment air filter is no longer available as a factory option. With the redesigned HVAC case, there is no longer a cavity for the filter. The GM parts catalog indicates there is a replacement filter available; however, there is no provision for it.
Hope this helps,
William
Saturday, May 24th, 2025 AT 5:34 PM
CLINTON SAMUELS
  • 6 POSTS
Thank you. This I can confirm.
Saturday, May 24th, 2025 AT 5:39 PM
CANNON1349
  • 864 POSTS
In any case, thanks for using 2CarPros. Please feel free to return with any other concern you might have regarding your automobiles. Tell a friend!
Thanks,
William
Saturday, May 24th, 2025 AT 5:46 PM
CLINTON SAMUELS
  • 6 POSTS
Will do.
By the way when replacing a blend door actuator, should the new one marker be set to the same position as the old one or left at the 12 o clock. Mark it came on?
Saturday, May 24th, 2025 AT 6:31 PM
CANNON1349
  • 864 POSTS
The HVAC doors will be in the last place or default setting, as you can see on the old actuator. Most of the time the new actuator will come with a small tool to turn the HVAC door so you can fit the new one in. You don't want to turn the new one and risk breaking the nylon gears inside. If there was not a small tool included I use the old actuator as a key and turn it by hand. You can also cut off the gear and use it.
William
Sunday, May 25th, 2025 AT 8:16 AM
CLINTON SAMUELS
  • 6 POSTS
  • 6.0L
  • V8
  • 4WD
  • 99,000 MILES
I see no access door as described by videos.
Sunday, May 25th, 2025 AT 11:13 AM (Merged)
STEVE W.
  • 15,299 POSTS
There is no factory provision for an HVAC filter on the 2004 - 2008 version, which stopped in 2003 when they changed the design and removed the filter.
CLINTON SAMUELS
  • 6 POSTS
How do I reset the engine air filter life monitor?
STEVE W.
  • 15,299 POSTS
Change out the filter then push the rubber end of the restriction monitor and it should reset. If it doesn't reset, it's likely from age. You can replace it but as long as you check and change the filter as needed it's not an urgent thing to have.
CLINTON SAMUELS
  • 6 POSTS
Thank you very much.
STEVE W.
  • 15,299 POSTS
You are welcome.
