Engine stops
JDL
  • 16,098 POSTS
With engine running, that should be alternator out-put. Have the alternator tested, sounds faulty to me. You also need to make sure the battery has a full charge. The generic spec for a full charge is around 12.6 volts, measured across battery posts, everything, engine, off.
Wednesday, November 13th, 2019 AT 6:50 PM (Merged)
ROADMASTER1992
  • 1992 BUICK ROADMASTER
Engine Performance problem
1992 Buick Roadmaster Two Wheel Drive Automatic 135000 miles
car is cutting off when in reverse and the gas hand is not working what could be causing this I have put a new battery and this is still happening
WRENCHTECH
  • 20,761 POSTS
You could have a fuel pump problem but you would need to test it with a fuel pressure gauge to determine that.
ELEEGE
  • V8
  • 197,000 MILES
My buick reacts as thouth it is starving for gas when I turn to the extreme right, or left, and press hard on the accelerator.
As long as I am going straight, I can stop in the middle of the street and press hard and it reacts fine,
however if I turn it stall, stumble, or shut down all together.
2CARPRO JACK
  • 11,533 POSTS
The power steering system shouldnt drag enough to cause that kind of problem with a V-8. Does the engine idle a little low? At that mileage it may need the Idle Air control valve cleaned along with the passages for it. This will stabilize the idle quality and should help. You can try wiggling thewiring harness under thehood as well to see if it causes the engine to stumble or die. Sometimes bad connections can do what you describe.
ALONSO COTA
  • V8
  • 188,000 MILES
I have a 1992 Buick Roadmaster it works just fine has alot of horse power but after driveing it for about 20 or 30 min it like wants to die out on me at a light? I noticed that if I hold the break and giveing it just a lil bit of gas as in to make it idle a lil higher it wont die on me
It dont over heat or smoke it has no knocks or leaks what could be wrong with it?
JDL
  • 16,098 POSTS
Hi, how long since a tune-up? Any trouble codes? You may need to clean the throttle-body and check iac- idle air control.
