1998 Buick Park Avenue belts and horn
JEFFMIN
  • 1998 BUICK PARK AVENUE
  • 6 CYL
  • 150,000 MILES
I can't figure out why my horn won't work, I checked the fuses, they seem fine, I can't get the steering wheel cover off to check there. Also I have to change my serp. Belt, Is it true I have to jack up the moter and remove the mounts to change the belt? If so that seems a little much.
Thanks Jeff
Do you
have the same problem?
Sunday, June 27th, 2010 AT 9:23 PM
BLUELIGHTNIN6
  • EXPERT
Did you check horn relay? If relay and fuse is good then test the horn by supplying 12v direct power to it. If it sounds then either wiring issue or horn pad/switch is bad. If doesn't sound then horn needs replaced. For the belt. Shouldn't have to, that is only required on the malibu and cutlass models. The park avenue should just have to loosen tension and remove belt.
Monday, June 28th, 2010 AT 12:21 AM
Recommended Guides
