Brake lights not working?
HENDRIX09
  • 2005 JEEP GRAND CHEROKEE
  • 4.7L
  • V6
  • 147,000 MILES
They don't work when pressing pedal. I replaced fuse and stop switch still nothing hazards work back ups work blinkers. And the interior lights turn on and off randomly
Thursday, August 7th, 2014 AT 4:50 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,302 POSTS
There is a stop light inhibit control relay (check the wiring diagrams) that goes out, here is a wiring diagram that will show you where it is and a guide on how to test it.
Here are the relay locations (below). Please run this test and get back to us so we can continue helping you.
Wednesday, March 15th, 2017 AT 1:20 PM
ANNI369
  • 2004 JEEP GRAND CHEROKEE
  • V8
  • 4WD
  • 93,000 MILES
My brake lights stopped working, I checked the fuse, and replaced it, but they still dont work. All other lights are fine. What might be done about this?
Wednesday, March 15th, 2017 AT 1:21 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Is the "cyclops" working? High mount brake light? If no then check the stop light switch on the brake pedal arm, if yes, check the multifunction switch(blinker).
JTTLR
  • 5 POSTS
I had the exact same problem. If you go to an auto part store and ask for a brake light switch they will have one. Its about 12 bucks. Take to a dealer ship and ask them to put it in. I did and they done it for free. Good luck
WRENCHTECH
  • 20,758 POSTS
You need to test for power and ground arriving before concluding that. Here is a guide
CJ MEDEVAC
  • 11,004 POSTS
Does it have a "squeezer dealee" connecting the cable to the clamp? Clean it too! Sometimes you can flip, the top of the squeezer over, and get more pressure on the cable
as for the rear lighting, might not be burned out, lots of problems with the "twisty light holders"---on the holder, sorta bend the brass contact out some more.A little sanding on the circle, of the tail light side, smear on a little "dielectric grease". Presto, your fixed. Might as well do 'em all. It's only a matter of time!
THE MEDIC
TANGO307
  • 2000 JEEP GRAND CHEROKEE
  • V8
  • AWD
  • 158,455 MILES
Electrical problem
2000 Jeep Grand Cherokee V8 All Wheel Drive Automatic 158455 miles
Brake light works fine when brakes applied. Tail light works fine when turned on. With lights on and apply brakes, tail light goes out and no brake light. Only on left side, right side works well and middle lbrake light on top of lift gate works fine.
BLUELIGHTNIN6
  • 16,542 POSTS
This is a grounding issue, you will want to inspect ground wiring at both taillight assemblies to ensure wiring is connected properly and not dirty or damaged.
TANGO307
  • 2002 JEEP GRAND CHEROKEE
  • 180,000 MILES
I've been told that my brake light doesn't work with the headlights on because of a broken ground wire. How do I repair the ground wire?
CARADIODOC
  • 33,760 POSTS
You find where it's broken first. That determines how it's repaired. You might install a new terminal, splice a cut wire, or if it's severely corroded, run a new wire. If the wire is corroded off a socket, replacing the entire socket is usually easiest. Some vehicles use printed circuits on the lamp housings and those can develop a hairline crack. Some can be repaired. Some have to be replaced.
ROBIN MCCOY
  • 4.0L
  • 4 CYL
  • AWD
  • 2,000,000 MILES
No brakes lights.
Wednesday, March 15th, 2017 AT 1:22 PM (Merged)
CARADIODOC
  • 33,760 POSTS
Could you provide some hints or observations to analyze? Have you checked the fuses? Brake light switch? Do the other lights work correctly? Do you have cruise control? If so, does it work and does it cancel when you tap the brake pedal?
KEITHHAUN
  • 3.7L
  • 6 CYL
  • 4WD
  • 150,000 MILES
Third brake light not working the other ones are ok. Plugged in one that works it did not light. Is there a separate fuse from the other lights? Could there be a broken wire and where?
Saturday, November 9th, 2019 AT 3:17 PM (Merged)
  • 108,355 POSTS
Have you checked to see if there is power to the light socket? There is no separate fuse, so if there is no power to the socket, there must be a broken wire. The only thing you can do is trace the power supply to locate the break.
SATURNTECH9
  • 30,869 POSTS
There shouldnt be a seperate fuse if there is a broken wire wouldnt know where it was without looking. Also what are missing at the light the power or ground side of it?
REDNECKPEN
  • 110,000 MILES
The two bottom brake lights work as long as the lights are not on. When the parking lights are on, the two large lights go completely dark. I have checked all the fuses and I have replaced all the bulbs in all three lights. There are a couple of other electrical quirks as well. The tire monitors are off and the seatbelt light stays on all the time. All I really care about is the brake lights.
DANGIT!!
  • V6
  • 120,000 MILES
Please help. Initially, had no rear lights at all. Replaced brake light switch and fixed tail lights.
Fuse was blowing immediately when I put in new fuse. Now, I have tail lights, blinkers and reverse lights, but all three brake lights out and now fuse blows only when I push brake pedal. Then I thought maybe was socket. Replace two of six, still blowing fuses. Now about to recheck each socket one at a time and the third light wires. If that does not work then I am in bad way.
Please, any ideas?
CATAFINA
  • 98 POSTS
The hot wire that goes to the brakes is shorted to ground. That is the only way for it to blow the fuse.
DANGIT!!
I think I finally got it right. I realized that I somehow put back two sockets that were bad and kept out the good sockets (I was very tired and aggravated by then and had several interruptions) careless oversight on my part.
All good sockets are in now and so far the fuse is also still good.
Still have nine of the twenty five pack of fuses I bought.
Saturday, November 9th, 2019 AT 3:18 PM (Merged)
CARADIODOC
  • 33,760 POSTS
Here is a trick to put in your memory banks for the future:
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a twelve volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it is not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
