Tell me all the specific tools I will need in hand to change my brake rotors
TRIXIE TALIULU
MEMBER
2013 SCION XD
1.3L
2WD
56,000 MILES
I was wondering if you could tell me all the specific tools I will need in hand to change my brake rotors and brake pads? For both front and rear.
Taliulu
Tuesday, May 23rd, 2017 AT 10:32 PM
KEN L
MASTER CERTIFIED MECHANIC
You will need to jack the car up first either front or rear first. Also you will need a lug wrench and a basic set of tools. ie sockets and wrenches which you can get from Amazon.
Cheers, Ken
SPONSORED LINKS
Friday, May 26th, 2017 AT 3:40 PM
DALMEJO
MEMBER
1 POST
2012 SCION XD
4 CYL
RWD
AUTOMATIC
55,000 MILES
Hi, so my brake pedal goes to the floor with little to no pressure. The car still brakes but barely, pretty much only when the pedal is pushed all the way to the floor. It barely stops. The master cylinder was replaced with a new one and the brake fluids are fine with no leak and is full. I think I need to do the brakes.
Friday, February 12th, 2021 AT 10:07 AM
(Merged)
SEVAG P
MECHANIC
its sound like brake system needs proper bleeding air is trapped inside the system. also check brake fluid level and if any leak found.
Check the diagrams below how to replace brake pads and rotors, also brake bleeding procedure specific to your vehicle.
hope these helps .
thank you.
Images (Click to make bigger)
(Merged)
MIKEE1983
MEMBER
2008 SCION XD
1.8L
6 CYL
2WD
AUTOMATIC
135,000 MILES
I watched your video on how to install brake pads but I can't figure out how to get the piston pushed back in. Is there an alternative to using a channel lock to get it back in? Thanks in advance.
Friday, February 12th, 2021 AT 10:08 AM
(Merged)
SATURNTECH9
MECHANIC
Are we talking about the front calipers or the rear calipers?The front ones you can use a c clamp. The rears some of them screw in let me know which calipers the front or rears?
SPONSORED LINKS
(Merged)
MIKEE1983
MEMBER
The front calipers. I've tried using a C-clamp but nothing doing. It wouldn't move at all.
(Merged)
SATURNTECH9
MECHANIC
There is nothing special about compressing the front calipers. Did the pads just wear out is that why your changing them?You could get a caliper compressor there pretty cheap. They have one side looks like the back of the brake pad and there is a forcing screw in the middle of it. You leave a old brake pad in the caliper against the caliper piston. Then put the caliper compressor forcing screw against the old brake pad and screw it in until the caliper compresses.
(Merged)
MIKEE1983
MEMBER
Yeah the pads just wore off. Will try the caliper compressor, thanks.
