HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
BMW
325
Engine
Symptoms
Not Running
1992 BMW 325 not start
FERRARITARNOW
MEMBER
1992 BMW 325
6 CYL
2WD
AUTOMATIC
230,000 MILES
My problem i'ts code 55 ( DIS ignition system output stage) car not start.
Wednesday, February 13th, 2008 AT 11:28 PM
DOCHAGERTY
MECHANIC
It is possible the DME is faulty.
Saturday, April 5th, 2008 AT 11:17 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1992 Bmw 325 Engine Stopped And Will Not Start
Engine Mechanical Problem 1992 Bmw 325 6 Cyl Two Wheel Drive Manual Stopped For A Redlight And It Stalled. Will Not Start. Will Turn...
Asked by
allineman
1 ANSWER
1992
BMW 325
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Bmw 325 Won't Start
Engine Mechanical Problem 1992 Bmw 325 4 Cyl Two Wheel Drive Automatic Installed New Engine Because Old One Was Frozen. Compression Is...
Asked by
gibsonjrd
1992
BMW 325
Car Ran Fine, Now Won't Start! Tries To Start With Starting Fluid. Fuel Pump Is Good, Fiter Is Clean, Gets Fuel At Rail But Not Firing...
Asked by
ef9onnos
1 ANSWER
1992
BMW 325
1992 Bmw 325 Feul System
Engine Mechanical Problem 1992 Bmw 325 6 Cyl Two Wheel Drive Automatic 120xxx Miles My Son Has A Bmw 325i He Ran Out Of Gas Now It Wont...
Asked by
roetony
1992
BMW 325
1989 Bmw 325 Turns Over But Won't Start
Aquired The Car Not Running, Car Will Start With Starter Fluid But Then Dies. I Figure It May Be The Fuel Pump But What Else Should I Check...
Asked by
bama22
1 ANSWER
1989
BMW 325
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
