Airbag light in dash stays lit
CARGUESTIONS
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • 220,000 MILES
My airbag light in dashboard came on and stays on. I was asked by a relative of mine who had same problem, if my horn still blows and I said yes. He said he took his vehicle to a mechanic that told him it was the Clock Spring located in the steering wheel that needed to be replaced. He ordered one from Amazon and paid $50.00 for it. The mechanic replaced it for him and that fixed the problem. Can I assume that is what is causing mine to stay on because his vehicle was not a 2004 Camry four cylinder with 220,000 miles like my car but his is a Toyota?
Do you
have the same problem?
Wednesday, March 6th, 2019 AT 12:16 PM
  • EXPERT
Good morning,
No, you cannot assume it at all.
There is a fault code set for the system and you need to get the fault code read so we can narrow the area of failure.
It would be an expensive guess if it is not.
A part store and read the code for free. When you get the code, let me know so we can continue.
Wednesday, March 6th, 2019 AT 2:43 PM
Recommended Guides
