Blower fan not working
LISROB
  • 2012 GMC SIERRA
  • V6
  • 4WD
  • 100,000 MILES
The fan for the heat works one day and not the next. I have replaced the resistor about a month ago.
Monday, January 13th, 2020 AT 3:47 PM
  • 52,797 POSTS
Good evening,
You will need to do some voltage tests to determine the issue.
You need to check for voltage to the resistor with the key on. It could be either the resistor or the blower motor.
Monday, January 13th, 2020 AT 4:45 PM
JJ JOHANNSEN
  • 2008 GMC SIERRA
  • 5.3L
  • V8
  • 4WD
  • 105,000 MILES
My blower motor works when I first start my truck but then after it warms up it will shut off and not blow any air out. The air is hot but the blower will not work.
Saturday, December 26th, 2020 AT 10:10 AM (Merged)
  • 52,797 POSTS
Good morning
I attached a wiring diagram for you to view.
When the blower stops working, you need to do some voltage testing at the motor and the resistor to see which unit is causing the failure.
SONYA BROOKS HOUCK
  • 2007 GMC SIERRA
  • 5.2L
  • V8
  • 4WD
  • 201,000 MILES
Turned on A/C today and fan was not working, at any setting. Nothing coming out of the vents. Tried everything. Replaced under hood relay. Did not fix problem. Switch in truck is working. Just nothing blowing out of vents. Not sure what to do next
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
It sounds like you have a blower motor that has gone out but to be sure lets run a simple test using a test light to test for power at the blower motor. This guide will show you how.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
and
Here is the blower location and the wiring diagrams so you can see how the system works.
Check out the diagrams (below).
Cheers, Ken
ENJOY425
  • 2006 GMC SIERRA
  • V8
  • 4WD
  • 67,000 MILES
I turn the fan switch from low to high and nothing is happening, nothing blowing out the vents, I have no heat ac or defrost. Usually you can hear the fan motor going when on but there is no noise, nothing. I have checked all fuses and they are okay. Just wondering if it could be the resister or the blower motor. I have not checked to see if there is power to the resister or motor. The fan just stopped working no warning or any type of noise just quit, maybe the switch. I am hoping someone could guide me in the right direction before I start taking things apart. Your help would be appreciated.
Thank you,
Gary
It sounds like you have a blower motor power resistor has gone out, but to be sure here is a guide to show you how to test it and a diagram below to help you see what it will be like for your truck:
I added the wiring diagrams so you can see how the system works.
Check out the diagrams (below). Please let us know what you find.
Cheers
ENJOY425
I check the blower motor to the battery it works fine. So I checked out the guide and figured out the power resistor has bad. I got a new one for $78.00. All fixed!
Thanks, Gary
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
GMC11
  • 2006 GMC SIERRA
  • 6.6L
  • V8
  • TURBO
  • 4WD
  • 320,000 MILES
So I proceeded to replace the module after reading one of your posts. A little wiggle and it came back on and worked as it should for another two months. Then quit again so I purchased the module and the wiring kit since one of the prongs on the seven pin connector was melting/burnt. (The black wire) Double and triple checked everything. As soon as I plugged it in it got extremely hot and started smoking.
Help?
Not sure what to do next?
  • 108,192 POSTS
It sounds like you have a direct short. You indicated the purchase of a new wiring harness. Is it an OEM part or aftermarket? Did everything match up with what you had? Is it possible for you to take pics so I can see what is happening and indicates which wires started smoking? Or if it was the module smoking, let me know.
I attached a pic below of the wiring schematic of the HVAC blower motor system. When you say module, are you referring to what in the picture is also called the blower motor control switch?
GMC11
Oh my gosh! I feel really dumb. After walking away for a minute and coming back I noticed I crossed two wires. Probably after repositioning (basically upside down for tool placement).
I’m sorry if I wasted anyone’s time.
Although the new module does get fairly warm to the touch still. Is that normal?
All parts were from Napa.
GMC11
I also attempted to send pics. Not sure what happened there.
Thank you so much for the swift reply!
GMC11
Warning to others, the Napa repair harness has all black and white wires. Other than that it’s identical looking.
  • 108,192 POSTS
It isn't out of the ordinary for it to get warm, but not hot. Is it working properly now? Also, you didn't waste anyone's time. We're here to help if we can.
SIERRA336
  • 2005 GMC SIERRA
  • 5.3L
  • V8
  • 4WD
  • 163,000 MILES
The heater blows hot air, but the fan blows like it is on low even when it is on max.
Saturday, December 26th, 2020 AT 10:11 AM (Merged)
HMAC300
  • 48,601 POSTS
Check the blower control processor by blower motor, it may be bad. Scan for codes to see if that is the problem and not control module. See picture.
STAN JONES
  • 2003 GMC SIERRA
  • 4.8L
  • 100,000 MILES
Blower quit working, it was only working on high speed. Replaced blower motor resistor but still nothing. When I change the fan speed I can hear a click down by the blower motor.
  • 52,797 POSTS
Good evening,
I attached a wiring diagram for you to view. Check the wire I circled and see if it has power with the key on.
MIDKNIGHT
  • 2003 GMC SIERRA
  • 170,000 MILES
I have a 2003 gmc serra z71. The heater blower motor stopped working. I have replaced the resistor, (at $55.00)and didn't solve my problem.
