AC Blinking Green Light, Does not cool
CHGOGRFX
  • 2002 TOYOTA CAMRY
  • 2.4L
  • 4 CYL
  • 4WD
  • 142,000 MILES
When I push the AC button in my 2002 Camry it comes on for few seconds and then starts blinking. Air keeps flowing but its not cold. I was able to hold down the AC button for a few seconds and get it to come back on yesterday, but that doesn't work today. Can it be just low freon or is it some sort of relay/sensor? What should I do?
Do you
have the same problem?
Wednesday, May 27th, 2015 AT 10:23 AM
HMAC300
  • EXPERT
With a/c on run above idle and go under hood and see if large pipe from evaporator is cool or frosty if it is it'snot low on Freon. See if compressor is engaging. Check fuses under hood and in car if it is automatic temp control where you set the temp it could be anything like a sensor/actuator etc. So you will need to take to a garage to get it scanned as auto parts can't scan that.
Wednesday, May 27th, 2015 AT 12:15 PM
Recommended Guides
