Fuel filter location?
TIMOTHY CARTER2
  • 1999 DODGE RAM
  • 5.9L
  • V8
  • 188,000 MILES
Where is the fuel filter?
Does it have one other than the one in the tank?
Thursday, November 21st, 2019 AT 2:21 PM
  • 52,797 POSTS
Good afternoon.
The filter is at the fuel pump. It is the only one listed. I attached a picture of the location of the filter for you to view. Check out the diagrams (Below). Please let us know what happens.
Thursday, November 21st, 2019 AT 2:39 PM
FIRECHIEF
  • DODGE RAM
1999 Dodge Ram Where is it located. Thanks
Thursday, August 27th, 2020 AT 12:05 PM (Merged)
  • 75,992 POSTS
Check at the fuel tank where the fuel pump module-its right beside the pressure regulator.
GUTTERMAN67
  • 1999 DODGE RAM
  • V8
  • 4WD
  • 147,000 MILES
Can not find fuel filter on frame
JDL
  • 16,098 POSTS
Welcome to the forum, the fuel pressure regulator has an internal filter, the regulator is on top of the fuel pump module. There is no separate fuel filter, that I know about.
FINALLYFREE43
  • 1999 DODGE RAM
  • V8
  • 4WD
  • 174,000 MILES
Where is the fuel filter located on a 1999 Dodge Ram 1500, 4x4, 5.2 l
CARADIODOC
  • 33,757 POSTS
What's the symptom? Except for diesels, you will never solve a running problem on a Chrysler product by replacing the fuel filter.
PAINTER969
  • 8 POSTS
I replaced the fuel pump in my 2001 at the adviace of a friend. After replacing the $130 fuel pump I realized all I needed was a tune up. Replaced plugs, wires, cap and rotor button ran great after and now I have an extra fuel pump that I dont need.
MOTANUL79
  • 1998 DODGE RAM
  • V8
  • 168,000 MILES
I can't not find the gas filter!
Thursday, August 27th, 2020 AT 12:06 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Should be where the cab and the bed meet in that general location. Follow the fuel lines from the tank up to the engine, you will find it that way.
There is also one on the fuel pump.
PETECT
  • 8 POSTS
I was told there is no filter under the truck. Only on the pump
BLACKOP555
  • 10,371 POSTS
Also there may be one in the fuel pressure regulator.
Strange theres no filter under the truck.
SHAN1922
  • 1998 DODGE RAM
  • 6 CYL
  • 4WD
  • 88,000 MILES
I staled in the middle of the inter section. It turns over but when I give it gas it dies. I had someone look at it and they said it was a fuel problem. The fuel isnt getting to what ever part it needs to run. They said to try to replace the fuel filter then next thing would be fuel pump. Does that sound right? How would I change that since the filter is under the pump>?
JDL
  • 16,098 POSTS
Hello, I'd use a gage and double-check fuel pressure. I'd also check for good B+ and ground at the pump. Check for codes. If you need to get at the pump, look and see if you can reach anything, if not, lift the bed or drop the tank.
JARED13SBS
  • 1998 DODGE RAM
  • V8
  • 4WD
  • 124,500 MILES
How do you change the fuel filter from inside the gas tank?
JDL
  • 16,098 POSTS
Hi, not sure which filter your talking about? If strainer that is on the end of fuel pump? You'll have to drop the gas tank and remove fuel pump assembly.
There is a regulator/fuel filter on top of the fuel pump assembly, not in the tank. Don't know if you can reach without dropping the tank?
MCBUTLER
  • 1998 DODGE RAM
  • 6 CYL
  • MANUAL
  • 156,274 MILES
How do I change a fuel filter on a 98 dodge ram pickup 1500 series 6 cyl engine
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,259 POSTS
The fuel filter is located at the top of the fuel tank. Here are some diagrams of where the filter is located in the tank. (Below)
It is with the pressure regulator.
Cheers, Ken
JELLIS85
  • DODGE RAM
Could someone tell me were the fuel filter is located. Motor is a 318. Thanks
MERLIN2021
  • 17,250 POSTS
Sing a twisting motion pull fuel filter/pressure regulator from the rubber
grommet on the fuel pump module, ensure it's not pulled more then 3 inches out
or damage to the pressure regulator can occur! Dodge recomends the tank be
removed to service the filter/regulator! It's on top of the gas tank!
https://www.2carpros.com/forum/automotive_pictures/62217_Gas_Tank_1.jpg
