94 Chevy Camaro
Recently Had New Engine Installed And Now The Oil Pressure Needle Is Jumping Around Is This Related To The Engine Or Is It Another Problem...
steph
Steering Feels Out Of Control
Hi, I Have A 1991 Bronco Xlt, 4x4. Problem Is The Steering Seems To Overcorrect When Barely Turned. When Let Go Of It Is Almost Perfectly...
BroncoBetty
88 Astro Hood Latch
Tried To Open Hood With Inside Release-didn't Work. How Do I Get Under The Hood?
Bear
Obnoxious Squeaking
1990 Honda Civic Dx (204k) From The Front End Of The Car Comes A Loud Squeaking/rubbing Sound That Is Most Evident Between 15 And 45 Mph....
cbehrens
92 Mazda B2600i Pickup
I Have A 92 Mazda B2600i Pickup That Starts Fine But Shortly After Warming Ups Starts Faltering Anf Missing. If The Accellerator Is...
kpthomas
MAZDA TRUCK
S-10 Dies Randomly
I Own A 2001 Chevy S-10, 4.3l V-6 Extended Cab With 68,500 Miles On It. About A Month Ago My Check Engine Soon Light Came On And I Got It...
Ckmn463j
2000 GMC Sierra Running Then Stopping
This Morning My Truck Just Up And Quit. I Left The House And When I Tried To Accelearate It Stalled. Hard To Start And Would Idle At About...
yukonsly
GMC C2500
95 Camaro No Brakes
I Disconnected The Brake Lines From The Abs System To Do A Motor Swap Now I Have No Brakes And Have Tried To Bleed Them But This Does Not...
cmiles1943
'55 Chevy Pu...steering Problems
I Have A '55 Chevy Pu I'm Working On And I'm Trying To Improve The Steering. I Had Power Steering Installed Without The Independant...
jcwebb
1955
Mini Cooper Starting Problems
Hi Huys, I Brought A 02 Mini Cooper A Month A Go Or So And Lately Have Had Trouble Starting Especially When Cold/wet. It Turns Over...
adamstillwell
MINI COOPER
Grand Am Gt
Can Someone Help Me I Have A Grand Am Gt 1997 It Starts Up And Shut Right Off What Can It Be
rodney
Neon 98, Timing Belt Set Up..............help.
Hello, I Want To Introduce Myself And Also Ask For Assistance As My Dodge Neon Is Giving Me Problems, Here's What Happened: While Driving...
ipardo
Heater
My Heater Only Blows Cold To Warm Air. Never Gets Hot. I Replaced Thermostat. Flushed Radiator Put New Antifreeze In. No Leaks. What Else Is...
10foTuck
MAZDA 626
Abs Lights Appeared The Interior And Exterior Lights...
The First Time My Problem Occurred Was During A Snow Storm In Mid-december 2005 I Was Driving And About 20-30 Minutes Into My Trip I Heard A...
Vicki Billick
MERCURY SABLE
89 Mustang
My Daughters Timing Belt Broke On 89 2.3 Mustang How Do I Set Timing For The New Belt
clone4069
2002 Intrepid 2.7 Fault Code P1776
I Get This Code In Top Gear. The Car Jolts Slightly Before The Warning Light Comes On. It Goes Into Limp In Mode. It Clears Itself On...
The Brit
2000 Silverado Driver Side Window Failure
Having A Problem W/ Either The Window Switch Or The Window Motor. When The Switch Is Pressed To Raise/lower There Is A Clicking Noise From...
carter
93 Engine Swap Possibilities??
I Have A 93 Mazda Mx-3, It Has A 1.6l Sohc With 200,000kms. I Was Told That I Can Put A 94-95 Mx-3 1.6l Dohc Engine In, Do You Knoe If...
xrricky
MAZDA 323
Driveshaft Bent
I Have A Jaguar 96 Xj6 I Had A Vibration A Few Months Ago And My Mechanic Said He Needed To Replace A Flex Disc. But, He Said I Didn'...
danamick
JAGUAR XJ6
2002 Mercury Sable Electrical
Hi My Name Is Vicki :cry: My 2002 Mercury Sable Only A Little Over 38,000 Miles On The Car Is Experiencing An Intermittent Problem. ...
Vicki Billick
MERCURY SABLE
Monte Carlo Overheating
My Son Has A 1999 Monte Carlo. It Overheats And Also Heater Isnt Blowing Warm Air. The Radiator Fluid Keeps Going Into The Overflow Tank And...
pattisw
CHEVROLET MONTE CARLO
92 Carolla
Toyota Carolla Dx 92 (automatic) We Have Changed Axles Due To The Damage Of The Cvs Several Days Ago. Since Then, The Car Seemed To Be...
emydinae
94 Pontiac Transport
Over The Past 6 Months, My Wife's 94 Transport Has Developed A Series Of What Might Be Called "accessory" Problems. The First Involved The...
bennett3
PONTIAC TRANSPORT
1990 Toyota Celica
Fuel Problems. How Many Fuel Filters Does This Car Have?
redrottie123
TOYOTA CELICA
Vauxhall Vectra 1.8 16V Idling Problem
Help. I Have A Vauxhall Vectra 1.8 16v That Keeps Cutting Out At Junctions Instead Of Dropping Down To Normal Idling Speed. I Have Changed...
waspi
1916
VAUXHALL OTHER
20233
20234
20235
20260
