Auto Shutdown Relay Dodge Truck
I Have A 1986 Dodge Ram 150 4 X 4. I Can Not Seem To Get Power From The Auto Shutdown Relay To The Fuel Pump In The Tank. If That Is The...
randal
03 Explorer- Check Trans Fluid
I Was Changing The Oil On My 2003 Explorer. It Is 4wd. There Was A Couple Of Drops Of Transmission Fluid Showing So I Went To Check It....
TresHuevos
1991 Mercury Tracer Headlight Problem
My 91 Tracer Has A Headlight Problem. When I Have The Headlights On And Use My Left Turn Signal The Headlights Turn Off Until I Turn The...
mofoindustries
MERCURY TRACER
Chevy Truck Slow Starting
It's A 2000 Chevy Silverado With A 6.0l Gas Engine With Automatic Trans And 4x4. 48,000 Miles. When Cold The Engine Starts Right Up. After...
wrufit
2000 Altima Hard Starting?
I Have A 2k Altima Gxe With 75,000 Miles On It That Starts And Runs Fine After It Sits For A Long Period Of Time(over Night), But In...
dansdr
System To Lean
Hello, I Have A 1999 Ford Expedition, And Sometimes It Is Idle To Low To Stay Running. It Stalls And Sputters. I Have To Keep My Foot On...
SicWitIt
Dummy Light Question 1996 K1500 Ext
When I Bought My Truck I Realized That A Few Of The Dummy Lights Were Blown Out, In Particular The Check Engine Light And The E Brake Light...
flynn
1999 Neon Missing
My Wife Has A 99 Neon 2.0 L Dohc. It Has A Miss, So I Have Changed Plugs, Wires, And Coil. The Code Is Telling Me A Miss In #4. When I...
Ziggy625
1995 S-10 4.3 Liter Timing
Hello There, I Was Wondering If Anyone Out There Could Help Me. I'm Working On A 1995 S-10 Pickup With The 4.3 Liter V6. This Thing Will...
JKuteZ28
2000 Ford Ranger/ Temp. Guage/ Low Reading
I Noticed Today That My Temperature Guage Barely Moved After A Short Trip Of About 3 Miles. The Morning Temperature Was In The Low 30(s). ...
dlemons
03 Mazda Protege Making Loud Squealing Noise When In...
I Have An 03 Mazda Protege And I Just Replaced The Two Belts On The Car. It Makes The Noise When I Put The Car In Reverse And Then When I...
nautica098321
MAZDA PROTEGE
Subaru Clutch Replacement
Need To Replace The Clutch In My 98 Legacy Awd 2.2 Liter And Was Wondering If It Would Be Easier To Take The Engine Out Or The Transmission...
eisanaa
SUBARU OTHER
Worth It To Replace Engine On 1989 Voyager LE?
Hi, We Are Trying To Decide If It's Worth It To Replace The Engine In Our Minivan. We Purchased The Car Used 2 Yrs Ago, Private Party...
travlinfamly
CHRYSLER GRAND VOYAGER
Ticking, Or Knocking Sound.
1993 Ford Probe, Ticks On Idle An Gets Worse On Acc. It Has No Power. The Ticking Is Very Loud.I Took The Front An Rear Valve Covers Off...
89hatch
FORD PROBE
Blinker Fuse Blows When Put Car Into Reverse.
I Just Got My Blinkers To Work. I Then Put My Car Into Reverse And It Blew The Fuse. The Blinkers Work Fine Until I Put The Car Into...
temptris33
Alarm Activated And Wont Shut Off
:( Ok I Have A 1996 Chrysler Cirrus And The Alarm Is Activated And Wont Shut Off. I Bought The Car Used And Boy I Am Regretting It So Far...
sandi
CHRYSLER CIRRUS
94 Mazda Mx-3 Frontend Troubles
I Have A 94 Mazda Mx-3 With 175000kms I Myself Have Put New Wheel Bearings In It And New Struts, It Also Has 4 New Tires And New Cv Axeles...
christoph
MAZDA MX5
Car Stalls
I Have A 1992 Olds 88 And It Skips And Back Fires Out Of The Intake And I Sounds Like It Is Popping Popcorn, It Is Weird. I Have Changed...
jeremeyrwhitney
Serpentien Belt
Belt Off Not Broken Need Diagram To Replace.
vetsday
CHRYSLER OTHER
1993 Nissan P/u Won't Start
I've Checked Everything I Can To Get This Truck Started All Relays Seem To Be Getting Power And I Can Smell Fuel Could Get The Truck To...
Ariesfire1975
NISSAN TRUCK
Heater Problems
I Just Got A 1993 Ford F-150 2 Wheel Drive With A 302( 5.0) When I Turn The Heater On All I Get Is Cold Air, I Have Already Replaced The...
msf7715
Struts/shocks
My Friend Has A 1995 Nissan Maxima & She Wants Me To Replace Her Struts/shocks All The Way Around; But How Do I Know If It's Not Just The...
greasemonkeydez7
NISSAN MAXIMA
Heat Problem
The Temperature Of The Car Rises And The Heat Start Blowing Cold Air. After A While The Temperature Goes To Normal And The Heat Start...
kutabale
NISSAN OTHER
Nisaan Altima 1996 Stops After Running For A While
I Have 1996 Nissan Altima. When I Bought This Car, It Had Transmission Rebuilt. Car Was Running Fine For Almost 1 Year.I Had A Small...
bpr2502
Warning Light
I Have A Warning Light That Has Appeared On My Dash Today Which States That It Is An Engine Warning Light, (amber In Colour). In My Manual...
Tone
HYUNDAI OTHER
20219
20220
20221
