93 Toyota Camry Transmission
How Do You Know If Your Transmission Is Going Or If You Just Need To Replace The Fuel Filter. I Just Started Noticing Problems On The 14th...
Alexander
E-150 HEAT CONTROL VALVE
I Have A 1989 E-150 Convershen Van I Hope Some One Can Tell Me Wheir The Heat Contol Valve Is Located, So That I Can Trurn It...
RONBO
1915
Mercury Villager Gas Smell
I Have Been Smelling Gasoline Both Outside And Inside My 1996 Mercury Villager Van (69,000 Miles). The Odor Occurs Sporadically, Mostly...
lizemery
MERCURY VILLAGER
Ho Can I Disarm The Alaram
I Bought 1987 Mercedes Benz And Park It At Home And Did Not Started The Car For Few Weeks, I Try To Start The Car But The Bettry Was Dead...
bobi99992000
MERCEDES BENZ OTHER
1988 Lincoln Towncar
I Need Help With This Old Beast, I Have No Dash Lights Do To A Wire Shorting Out, I Think It Blew Something So I Need Parts For This Old...
money_maker_21_05
Door Panel
What Would The Steps Be For Me To Remove The Passenger Side Door Panel On My 1993 Ford Explorer 4 Wheel Drive This Is So It Will Cost Me...
gail glandon
1995 Nissan Xe 4x4 Truck - Water In Door Or Under Cab
Looking For Help. I Can Hear Water Sloshing Around When I Am Driving When I Move From A Stop Or When I Turn Corners. It Has Been Raining...
amac
NISSAN TRUCK
Brakes And Parking Brake Repair
99 Nissan Maxima, 125,000 Miles. I Had The Brake Pads And Rotors Changed, Front And Rear. The Parking Brake Worked Fine Before It Went...
Ricolaw
NISSAN MAXIMA
Rotten Egg Smell
1982 Dodge Rampage.I Turned On My Heater And My Car Filled Up With This Horrible Smell Of Rotten Eggs. I Turned Off All The Vents But The...
castle
CHRYSLER OTHER
Cost For Valve Cover Replacement? 1998 Diamante
Would Anyone Know The Cost To Replace The Valve Cover Gaskets On A Mitsubishi Diamante? I'm Getting Prining At $550? Seems High? Thanks!
vernicci
MITSUBISHI OTHER
My Passenger Side Door Won't Close On 1997 Ford Escort
Please Help! I Cannot Get My Passenger Side Door To Close!
andreak
1987 Mitsubishi Truck
I Replaced The O2 Sensor, Retimed Engine, Regapped Distrubator, Truck Starts Out Fine Gets To About 45mph Then Suddenly Now Power...
cbeeican
MITSUBISHI OTHER
Blower Motor
I Have A 1992 Cadilac Deville The Blower Motor Went Out. So I Put A New One In. Tried It And It Does Not Work! Check All The Fuses On Driver...
pitbull
2002 Ford Explorer - Whirling/Whistling Sound
I Hear A Whirling/whistling Sound While I Step On The Gas To Accelerate. It Continues For A While When I Let The Pedal Go. But As Soon As I...
robnathan
1993 Infiniti G20 Near Stall Problem!!!
My 1993 Infiniti G20 Only Has 29,000 Actual Miles On The Entire Car. I Bought The Car A Couple Weeks Ago From A Towing Company, The Car Had...
David Zinn
INFINITI OTHER
Exhaust Manufold Leak
I Have A 1998 Ford 460 Engine With 48,000 Miles. I Have Attempted 3 Times To Stop Leaks In The Exhuast Mainfold (both Sides Leak). The...
Ronnie Jones
DELETED
Hello: Well Sounds Like You Drove It With Oil. When Oil Light Comes On A Car That Has An Idiot Light It Basically Means Stop Immidately And...
DARRYL
HARD SHIFTING 1997 JETTA GT
A Few Months Ago, My Automatic Jetta Started Shifting Hard In To Second Gear, But Only When It Was Cold, And Only Right After I Started...
smitty_kitty_678
94 Olds. Delta 88 Fuel Filter
My 94 Delta 88 Every Once In A While Starts "puttering" As Though Its Not Getting Enough Fuel, The Fuel Pump Was Changed A Year Ago. I Am...
supercharged6300
Fuel Filter Location
I Need To Replace The Fuel Filter In A 1995 Ford Aspire. Wandering Where It Is.
Summer Hinshaw
FORD ASPIRE
DTC PO720
I Have An 2001 Dodge 3/4 Ton Quad Cab 360 Magnum, And A Dtc Po720 Has Came Up, Should I Go Ahead And Replace The Speed Sensor Or Should I...
wheels297
1972
CHRYSLER OTHER
99 Dakota Intake Gasket
I Have A 99 Dakota 318. Ive Noticed A Significant Loss Of Power, Have A Small Ding When I Get On The Gas And I Go Through Alot Of Oil....
joshua_h519
I Get Up To Around 35 To 40 Mph The Truck Shakes?
I Have A 1993 F150 With The 4.9 Straight 6 Auto Trans With 84000 Miles On It. The Issue Is When I Am Driving As I Get Up To Around 35 To 40...
bjs82
2000 Dodge Neon
I Have A 2000 Dodge Neon. I Have A P0551 Code. Power Steering Code. I Reset It It Goes Away Unit I Reach Freeway Speed. What Can Be Wrong?...
busgil
Auto Shutdown Relay Dodge Truck
I Have A 1986 Dodge Ram 150 4 X 4. I Can Not Seem To Get Power From The Auto Shutdown Relay To The Fuel Pump In The Tank. If That Is The...
randal
20218
20219
20220
