92 Honda Civic LX Electrical Power Surges/ Blown...
My Check Battery Light Came On A Day After My Son Drove The Car Back To Chicago From New York, 208k Miles On It. The Repair Shop Who...
chipaul41
1992 Lexus - No Heat
My Car Does Not Put Out Heat. I Changed The Radiator Fluid And The Thermostat, Still No Heat. Please Suggest Other Things To Check. ...
tbalon
LEXUS OTHER
351 Windsor
Hi I Have A 351 Windsor And I Need To Now Where The Number On The Motor Is So That I Can Tell What Year The Motor Is So That I Can Get A...
aaron1989
1935
1980 20R Engine Thermostat
I Have A 1980 Toyota P/u With The 20r 4cyc Engine. The Water Pump Seized And I Had It Towed It To A Local Shop. They Suggested I Change...
k7acz
1980
87 F150 4wd, Won't Run When Hot
I Have An 87 F150 302 Fule Injected. It Runs Fine When I First Start It When Its Cold, But After While When It Warms Up It Hesitates When I...
hoss87
Idle Problem
I Have A 1990 Jaguar Xj6 And The Idle Jumps Often It Also Idles Very Very Low And Is Very Rough
$moneyman
JAGUAR XJ6
1993 Ford Aerostar
What Is The Firing Order For The Spark Plugs I Changed Them And Now It Is Not Running Correctly I Think I May Have Crossed The Wires.
billyh
FORD AEROSTAR
1997 Suburban Bent Axles?
3,000 Mile Ago I Had New Rear Drums And Brakes Installed. After Driving My 1997 Suburban 1500 For About 1400 Miles, The Rear Brakes Seemed...
ethan
1995 Mitsubishi 3000gt. No Tension On Belt!
1995 Mitsubishi 3000gt. Mileage:100,000. Hi, Im Having A Problem With Tension On My Timing Belt, It All Started When My Timing Belt...
mitsubishigtovr4
MITSUBISHI OTHER
Bad Oil Change Experience
I Have A 4 Month Old Vw Jetta - 2005 - The Newer Model. At 5,000 Miles I Took The Car In For The Required Warrenty Work That Included An Oil...
Hot Under The Hood
Safety Issues Removing Rear Shocks HELP!!!!
Is It Safe To Replace My Rear Shocks On My Ramp Or Do I Need A Lift. The Reason Why Is Because I Fear If I Remove The Shocks On The Ramp The...
Ramseydick
1989 Pontiac Firebird V6 2.8 Horrible Gas Milleage(...
I Was Wondering What Parts I Would Repair/replace/modify That Would Give My Car Better Gas Milleage :evil:
Ramseydick
PONTIAC FIREBIRD
Annoying Sound From Brakes Pathfinder 97
Hi: I've Been Having Problems With My Wife's 97 Pathfinder. The Front Brakes Have Been Screeching For Some Time Now And I Have Done...
lostcocopeli
Renault19 Prima 1.4 L Reg Starting Probs At Warm
Hi I Have A Renault 19 1.4 1993 Reg And I Have Been Having Starting Problems After Initial Start Up From Cold, The Problem Starts After I...
russws77
1919
RENAULT OTHER
MX6 92 - Initial Acceleration Revs Up Too Much
When Acceleration From Zero The Engine Revs Up To About 2000 Rpm, Then Starts Moving But The Revs Go Up As Well. After Reaching 30 Mph...
aeriver
MAZDA MX5
My Timing Belt Broke
My Timing Belt Broke And I Dont Know What Happened The Timing Belt Was Change And The Car Was Put Back In Time And It Wont Turn On The Car...
mojica
MAZDA 929
It Has A Occasional Real Bad Shimmy-shake In The...
Hi, I Am New To Carpros And I Am Having Difficulty With My 1999 Chevy Suburban. It Has 180,000. It Has A Occasional Real Bad Shimmy-shake...
crazycraig
Check Engine Light 1998 Chevrolet Cavalier
I Have A 1998 Chevrolet Cavalier, 4 Door Automatic, The Check Engine Light Has Been On Since I Acquired The Car 2 Weeks Ago. The Mechanic...
lgtu2
Heater Blower Motor/switch
I Have A 2002 Honda Civic Lx And My Fan Was Not Blowing Anything. I Was Told I Needed A Heater Blower Motor Replaced. Then I Was Also Told...
honcivlx
2000 Kia Sephia OD Light Is Flashing
My 2000 Kia Sephis Has Been Giving Me Trouble Starting Lately. It Will Always Start Eventually, But Sometimes You Have To Keep Turning It...
ballroc
KIA OTHER
Head Lights
I Have An 02 Blazer, I Recently Replaced A Head Light Bulb. The Replacement Bulb Shines A Good 3" Higher Than The Other. Is There A Way...
Michael Wadman
CHEVROLET BLAZER
S-10 Engine Swap
Will A 1986 2.8 F.I. Engine Swap With A 1983 2.8 Carb Engine. Will The Long Blocks Interchange If I Swap All The Parts From The 83 To The 86...
slotracer
Cam Sensor Broken And Pieces Of Metal In The Cam
1997 Ford Taurus - While Driving Down The Highway The Service Engine Light Came On And Some Hesitation Was Experienced. A Squeal Came From...
aimeefreyman
Driver Headlight Low Beam Not Working
Hello, 99 Chevy Trailblazer (has S-10 Body) Only Driverside Headlight (low Beam) Does Not Turn On. I Have Replaced The Bulb Socket, It...
DRAGON
Am/Fm Radio Problem
1997 Vw Golf. My Radio Is Doing Some Weird Stuff. The Face Says "safe" And When I Press Any Button It Has No Response. The Only Way I Can...
klara3z
20212
20213
20214
