2003 Ford Ranger Xlt 4x4
We Are Trying To Install A Conopy On This 2003 Ranger Xlt. We Can't Find The Wire To Connect The Third Brakelight. It Wants To Flash With...
wa-flyrod
92 Honda Accord Spark Plugs
I Just Bought A 92 Honda And Found Out That There Is Oil (a Lot) On Mostly The 1st And 4th Spark Plugs. What Does Theis Mean? I Think If I...
Derbyrace
89 Toyota Camry Won't Start
My Wife Was Driving Her 89 Camry Yesterday And The Car Just Quit Working. She Said It Basically Just Shut Off While Driving. She Just...
mike2111
Power Steering Works When Turn Right But Not When Turn...
Power Steering Works When Turn Right But Not When Turn Left Any Ideas?
ronpischinger
EAGLE VISION
Bank 1 On Left Or Right
I Have A 1996 Lexus Ls 400. The Dash Light Says "cam Shaft Position Sensor A Circuit Malfunction Bank 1 Or Single Sensor P O 340" Is...
MIKE DORMAN
97 Explorer Power Windows
97 Explorer Power Windows Quit Working With Driver Side Stuck Down. All Fuses And Relays Are Fine. Power Locks, Sunroof, Power Seats...
bilbo
01 Ford Explorer Power Steering Noise
I Have A 2001 4 Door Ford Explorer Xlt 51,000 Miles And Im New At Driving Suv's And Ive Just Noticed That When I Make Turns To The Left Even...
Explorer01
Looking For Parts Rodeo
1991 Isuzu Rodeo Ls Engine: 3.1litre Running Don't Care If It Is Burning Oil Just As Long As It Is Running And It Is An Automatic. 4x4...
Gearshifter
99 Grand Am Popping Noise When Turning
I Changed The Hub On The Front Left Side Because Wheel Speed Sensor Was Bad Again And Now I Have A Popping Noise When I Turn Someone Please...
slaw
Code 1391 On Dodge Ram 1500 4x4 5.9 Litre
I Have A Code 1391 On My 1999 Dodge Ram.I Have Already Replaced The Cam Position Sensor And It Still Won't Start. It Had 3 Codes On It The...
brownie
CHRYSLER OTHER
01 Explorer Transmission
I Have A 2001 4 Door Ford Explorer Xlt 51,000 Miles I Just Bought The Truck, The Transmission Fluid Seems To Smell Ok But The Red Color Is...
Explorer01
01 Explorer Rear Door Lock
I Have A 2001 4 Door Ford Explorer Xlt 51,000 Miles And The 2 Back Doors Dont Seem To Open Up From The Inside, I Switched The Child Safety...
Explorer01
ABS Shimmy?
96 Gmc Pu With Abs. When Slowing Down To Stop, Front End Shakes Like The Old Shimmy. No Brake Or Abs Warning Lights, Tire Pressures Equal...
John Bencicik
CHRYSLER OTHER
93 Legend Miss Fires & Exhaust Smells Of Raw Gas
Hi, Would Like A Little Resolution On This Situtation. At Idle, The Car Runs Rough (miss Fires) And Exhaust Fumes Smell Like Raw Gas....
stafawu
97 T&C Wacky Wipers
My 97 Town N Country Lxi Has Had Wiper Problems For About A Year. First They Would Just Go On For No Reason, Stay On For A Couple Swipes...
tomlew
Power Windows 97 Taurus
None Of My Windows Operate. The 30 Amp Fuse Under Hood Is Good And Replaced Relay Under Dash As Well. What Now? Randy
Rw
Brake Lights 87 F150
I Have An 87 F150 4x4 With No Brake Lights. The Turn Signal, Backup And Running Lights Work. The Brake Light Fuse Is O.K. The Switch At The...
agj60
How Do I Chang The Waterpump On A 1994 Ford Tempo
I Need Help On A Walk Through To Change Out A Waterpump On A 1994 Ford Tempo Can Someone Help Me Please
les
FORD TEMPO
Check Engine Light-1998 Mazda Protege LX
My Car Showed Check Engine Light Two Months Back. I Was Somehow Delaying The Trip To The Mechanic For Some Time After That. Meanwhile I...
rohitvt
MAZDA PROTEGE
Rear Disc Brake Rotor
I Just Replace Rear Brake Pads On My 2001 Daewoo Nubira. One Brake Rotor Had A Small Chunck Out Of It. Now When I Put Brakes On The Brakes...
bradyba
Starts, Then Immediately Stops.
Howdy Folks! I Have A 96 Isuzu Rodeo With A 3.2l V6. I Started Out By Having Problems Witrh Power. I Live On A Hill, And In First Gear...
rodeofreak
F150 Clutch
Just Put New Motor In 1998 F-150 4.2 Manual Trans Truck. 100k Miles. Kept The Original Clutch Becuase It Had Plently Of Life Left On It....
Palico
1915
Where Is The Flasher Switch Located On A 96 VW Golf?
Need To Replace The Flasher Or Blinker Switch On My 96 Volks Golf And Can't Find It. Anyone Know Where It's Located? Thanks
cwuestman
JAGUAR STARTER
Where Is The Starter Located In A 1986 Jaguar Vanden Plas 4.2 L
ARMAND11740
JAGUAR OTHER
Rough Idle
I Have A 2001 Gmc C1500 With A 4.3l. The Engine Run Very Rough On Idle Or Not At All. I Don't Any Sensor Code But I Do Have Misfire On All...
fdlecuyer
20178
20179
20180
