1999 Jeep Grand Cherokee Laredo 4x4 Deceleration Noise
Need Help! I Have A 1999 Jeep Grand Cherokee 4x4 Laredo 4.7 V8. It Has 243,000 Miles And I Love It. After I Have Driven It For About 30...
Eric Secor
Clutch And Flywheel 1994 300zx
I'm Gonna Buy A 1994 Nissan 300zx And It Needs The Clutch And Flywheel Replaced I Was Wondering If U Could Tell Me About How Much It Would...
arky187
NISSAN 300ZX
94 3000GT Change My Automatic Transmission
Car Info: 1994 3000gt Sl Automatic. Can I Change My Automatic Transmission And Put In A Manual Transmission, And Use The Service Manual -...
nightroad
Oil Pressure
I Drive A 1984 528e With 140,000 Miles. A Few Weeks Ago, I Had My Oil Changed, And Since Then, My Oil Light Is Acting Up. If I Drive On...
grey5283
BMW 528
BCM Question
I Recently Had My Bcm Replaced On My 2000 Saturn Sl. The Night That They Replaced My Bcm I Noticed That Some Of My Dash Lights And Ac...
Marble03
Idle Drop
I Have An 89 Prelude Si 2.0 Was Sitting For A While Not Shure How Long From Previous Owner Runs O.K But When It Starts It Almost Dies The...
kb96747
HONDA PRELUDE
Brown Foam In Oil
I Changed My Oil After 4000 Miles And It Had Some Brown Foam In The Oil And Also In The Oil Filter. I Have Done Some Very Aggressive Driving...
bgbeefy
93 Chev Trailblzr Buzzing Noise
Recently My Suv Makes This Annoying, High Pitched Buzzing Noise, Every Time I Accelerate, It Gets Higher In Pitch. Could Something Not Be...
djfreeze32
By 1989 Ford Bronco Jumps Out Of 4x4
It Will Jump Out Of 4x4 But If In Low It Stays In It Has 164000 On It Its A Good Running 5.0
sil438
1994 Saturn SL2 Intermittent Miss
I Have A 1994 Saturn Sl2 With 155.000 Miles And An Automatic Transmission That Recently Started Missing Intermittently. It's Been Getting...
jrleek
Problems With My Alternator Keeping My Battery Charged...
I Am Having Problems With My Alternator Keeping My Battery Charged. I Have Had The Alternator Checked At Serval Auto Part Stores And They...
curtis
1976
Hyundai Elantra 2001
My Wife's Car Is Starting To Mess Up, When You Shift It Into Gear It Starts To Jerk Like If You Are Letting The Clutch Out Too Soon, What...
jason933099
HYUNDAI OTHER
98 Mustang Exhaust Or Gas Fumes Smell Inside
1998 Mustang Gt, 4.6l, 5spd, 93,000mi Usually During The Summer While My A/c Is On And The Car's Been Running For A While, I Notice A...
doumerc
Too Much Road Noice
When I Go Straight You Can Hear Like A Tun Tunt Tun But I Turn Right And Sounds Smooth Plus When I Took The Suspencion To Put A New One On...
JuanCBX3
95 Camaro
I Have A 1995 Camaro Z 28 With 130000 Miles. A Couple Of Days Ago Everything Seemed To Be Running Fine. Went To Start The Car About An...
jdenning30
Engine Removal In A 98 Ford Explorer
I Was Wondering If Someone Could Give Me Some Steps On How And Or What To Do When Removing My Engine.
Hunsy
Can Running Engine While Oil Cap Is Off Cause Problems...
92 Toyota Tercell. Got An Oil Change Two Weeks Ago. Drove It Today For A Little Longer Than Usual And Noticed Lots Of White Smoke At Lights...
joyspirited
TOYOTA TERCEL
1993 Ford Tempo 4 Cyl.
My 1993 Ford Tempo Will Not Shift Gears At All And The Speedometer Will Not Work, This Problem Seems To Be Intermittent However And Will...
paps
FORD TEMPO
Audio Warnings
I Own A Chevrolet Impala 2001 Ls. Two Weeks Ago I Started Having A Problem Where When The Key Would Be In The Ignition And Doors Opened With...
FatherTyricius
Bronco Electrical
My 84 Full Size Bronco Has No Power Like The Battery Is Not Connected I Can Turn It Over At The Relay But No Lights Horn Or Ignition Inside
hartog
Electric Windows
Hi All, I Have A Mercedes Clk Conv', The Drivers Door Window Does Not Raise And Drop Half An Inch As It Should When The Door Is Opened...
Diplomat766
MERCEDES BENZ OTHER
Fan Clutch
1993 Full Size Bronco. 5.8 Litre (351 Ci) W/ac. I Have A Constant Chirp At Start Up. A Full Squeel After Running For About 1/2 Hr. I Used...
chilienojado
Mazda 323 1993
My Car Stalls Or Will Not Start Intermittently. An On-board Diagnostic Showed 29 Blips, And Supposedly This Means That The Solenoid Switch...
edalian
MAZDA 323
Code 13 O2
Tested The 02 But Stays At.800-.878 And Dosent Drop To.300 Dont Know Why But I Replaced The 02 And The Check Engine Goes On Still
JuanCBX3
1913
2002 Stratus Overheats - Need Partname
Hi & Thanks. I Have An 02 Stratus That Overheats. Upon Inspection, We Found The Problem: The Radiator Hose Leads To A
That Has A...
debster
20173
20174
20175
20260
