99ford Ranger
I Have An Airbag Light That Flashes When You Start The Truck, It Will Go Off. But Comes Back On And Stays On. Can You Help? Thanks.
wlg
ODB2 Code P0134 1996 Sunfire 2.4L
I Got My 1996 Sunfire Gt (2.4l Twin Cam) Scanned And Got A "p0134 O2 Sensor Circuit No Activity Detected (bank 1 Sensor 1)". Is There Any...
Xander Max
Hi Everyone
My Name Is Mai, I Own A 1993 850 Glt Volvo, Like My Other Cars I Usually Like To Perform Maintenance And Usually Gather Information Before...
mai
Unable To Start After Shutdown
I Have A 1996 Subaru Impreza L Wagon. The Car Refuses To Start Unless It Sits For Atleast 2hrs After Being Driven. The Starter Is Good...
lshotta
SUBARU OTHER
Chevy Truck Electrical Problem
I Have A 99 Silverado 5.3l I'm Having Problems With The Battery Discharging Until Dead. I Have Replaced The Battery And Alternator Twice In...
winddilla
Anti-Freeze Leakage
I Have A 1997 Chevey Astro Van Awd, I Know That I Have Anti-freeze Leaking I Just Down Know Why Or How To Check And Find The Problem. ...
Luis84
Headlight/taillight Malfunction
My 1987 Gmc S15 Has The Following Problem: Brake Lights, Turn Signal, Hazards Work Fine With Headlights Off. With Headlights On: No Brakes...
jefe
GMC S15
VIN Number Location
Where Would I Find The Vin Number On A 2001 Hyundai Santa Fe Other Than On The Driver's Side Dash? I Am Importing The Car Into Spain And...
eric doyle
HYUNDAI OTHER
1999 Chevy Malibu-will Not Run
I Have A 1999 Chevy Malibu Which Right Now Is A "lovely" Lawn Ornament. It Has Been To Two Mechanics And No One Seems To Know What It Is...
mkallen
98 Civic Heater Problem
My Car Is Blows Cold Air For A Long Time After It Has Heated Up. I Have Changed The Thermostat, And The Heater Valve Is Fine Too. Any...
lrgiles
2000 Ford Taurus P304 Code
My 2000 Taurus Has 124,000 Miles And I Am Getting A P304 Code. The Car Has A Coil-on-plug Ignition System. I Had A Major Tuneup At 105,000...
Richard Bee
Designated Cylinder #'s
I Have Code Telling Me The # 4 Cylinder Is Misfiring. How Do I Figure The Out The Designated Cylinders For A 1999 Nissan Maxima 6 Clylinder...
chfitz21
NISSAN MAXIMA
An Annoying Squeal...
My Daughter Has A 93 Sc2 And It Has Been Making An Annoying Squealing Noise For Some Time. We Had The Surpentine Belt Changed And It Temp....
indestiny
1993 Olds Bravada
Does Anyone Know Why The Guages Do Not Work All The Time? The Speed Ometer Works All The Time, But The Rest Only Works Every Now & Then...
Goofy57
Cooling Fans Inop
Cooling Fans Inop When Above Normal Temp. Fans Verified Good By Connecting Directly To Battery. Removed And Tested Engine Coolant Temp...
Caraman
DODGE OTHER
Wheel Bearings On '03 Caravan
I Have An '03 Caravan With 4 Wheel Disc Abs Brakes, 2wd. I Want To Do Some Preventive Maintenance On The Wheel Bearings When I Change...
jknaughton
92 Chevy Astro Van
My 92 Astro Van Died The Other Day. It Acted Almost Like It Had Run Out Of Gas. We Left It Where It Died Over Night, And Tried To Start It...
teena
Fuel Guage
I Have A 1999 Gmc Sierra. When I Fill Up The Gas Tank, The Fuel Guage Reads Empty, Yet If I Bump The Lever From Drive Back Into Neutral...
kjwest721
Instrument Cluster Lights
I Need To Replace The Bulbs Behind The Intrument Cluster In My 1991 Corolla Wagon. I Can Not Figure Out How To Get To Them Once I Get The...
lbritton
1999 Chevrolet Tahoe Electrical Problem?
1999 Chevrolet Tahoe 80,000 Miles When The Interior Light Override Switch Is Turned Off (so The Lights Come On When The Doors Are Open)...
someone_ate_my_pizza
Oil Leak
Is There A Way To Tighten The Plate That Is The Part Of The Engine Block Where The Oil Pan Meets The Block? It Appears To Have (4) Pieces To...
DEHALL762
BUICK LESABRE
1999 Ford Ranger
I Need To Replace The Water Pump On My 1999 Ranger, 3.0 Engine. All Breakdown Has Went Smoothly Up To The Fan Removal. I Tried Usinga...
cowboyjack
Oil Smell When I Turn On AC/Heat
I Had The Oil Pan Gasket Replaced Recently To Avoid Oil Leak. But I Am Still Getting Oil Smell When I Turn On Ac/heater. Mechanic Said That...
kissu_kk
Low Coolant Light
A Low Coolant Light Comes On At Times In My 2000 Taurus But The Resevior Is Full
mike miler
Converter
I Had My Cadalic Converter Replace Last Year And I Believe That Is Has Stop Up On Me Again. Instead Of Replacing It Again Can I Just Have...
theresa lee
MAZDA OTHER
20174
20175
20176
20259
