1993 Manual Transmission Problem
I Have A 1993 Honda Accord, Lx W/5 Spd Manual Transm. After Driving For About 30 Minutes The 2nd Gear Grinds Whenever I Shift Into It (...
bjggross
5-series Oxygen Sensor
I Have A 1995 525i. Can Someone Please Tell Me, Where Is The Oxygen Sensor? I Ordered A Replacement Assuming That I Could Find Where It...
jochen19
96 Jetta Oil Blow By? What Dose This Mean?
I Was Getting An Oil Change For My 96 Jetta Gl 2.0 5 Speed 180 000kms. They Siad That There Is Oil Blow Present In The Air Box. What Dose...
koolmike500
1997 Oldmobile Achieva Security System Factory Made
1997 Achieva 11500 Milesthe Security Light Comes On When I Try To Start The Car And It Shut Down. I Have Took It To A Gm Dealer They Can...
queenbee
Steering Wheel Won't Turn
I Have A 1996 Pontiac Grand Am With 108,000 Miles On It And Whenever The Temperature Dips Below Freezing In The Winter, I Have A Very...
danno_mn
1997 Honda Accord
I Have A 1997 Honda Accord With 90000 Miles. The Problem That I Am Having Is That When I Am Driving The Car It Will Shut Off And When I Go...
alex21
Clicking And Vibration
I Have A 97' Gmc Sonoma Extended Cab. It's A 2.2l 4 Cylinder 2wd Manual. It Has 63k On It. I Replaced The Transmission At 55k Due To A...
LitleFiredude49
GMC SONOMA
Fuel Tank
I Have A 1990 Honda Accord Exr 2 Dr Model. My Fuel Tank Is Leaking, Im Just Wondering If Theres Anything I Can Use To Seal It Up, Like...
rookyb
Weak Clutch At Start
1994 Acura Integra Ls, 122,000 Miles. Recently I Just Replaced A Slave Cylinder On The Integra, Bled It Fine And Installed Properly. The...
twisted65
Infinity J30t Stick In Second Gear After Downshifting
Just Bought A 1994 Infinity J30t With 118,500 Miles, But Engine Has 40,000 Or So Miles On It. I Was On My First Roadtrip, And While...
majorj30t
1930
INFINITI OTHER
Serious Electrical Issues With 1997 Pontiac Bonniville
My Son Has A 1997 Pontiac Bonniville Se With 150,000+ Miles That Has Serious Electrical Issues. The Only Exterior Lights That Work Are The...
khobson60
PONTIAC OTHER
ABS Speed Sensor
Does Anyone Know How To Test A Anti-lock Speed Sensor. I Have A 98 Chevy Astro Rear Wheel Drive And My Speed Sensor Is Located Toward The...
jhibbard
CHEVROLET OTHER
1997 GMC Suburban K1500 4X4 Intermittent Starting
When My Truck Does Start I Can Hear The Fuel Pump Working For A Second, And The Fuel Pump Relay Clicks A Few Times. It Starts, Runs And...
k1500broken
2001 Dodge Neon Trouble Starting
My 2001 Neon Has Recently Had Trouble Starting. I Will Try And Try And All Of The Sudden It Will Start. When I Turn The Key There Is No...
bill76
2 Caddys Both Electrical Probs...Wont Start
Hello Thanks For Reading This Message, I Have 2, 91 Caddy El Dorado's With About 150k On Both One Just Stopped Working All Togeather It...
burntbyte
1981 Honda Accord Electrical!!!
Hey, My Accord Runs Great, But One Day It Just Died As I Was Driving It. Ever Since The Battery Light Comes On And Stays On. I Had The...
blindaccord
1981
1988 Lincoln Mark VII Starting Problem
My Car (88 Lincoln Mark Vii) Has Problems Starting When It Has Been Driven Awhile. If I Drive 20 Or So Miles And Then Park At A Store...
Qbart
LINCOLN MARK VI
Heavy Exhaust
I Drive A 1990 Honda Accord And Lately It Has Been Giving Me A Problem. Currently It Is About 20 Degrees And There Is Snow On The Ground...
czy4heels
Change Transmission Fluid For '93 Camry Bought Used?
I Own A 1993 Toyota Camry With 160,000 Miles. I Was Told By One Mechanic That I Need To Replace My Transmission Fluid. However, A Second...
farmerbrent
99 Honda Civic LX Possible Map Sensor Problem?
Unfortunately, I Am Not Too Car Savy. Need Help. A Few Instances When I Would Stop My Car Abrublty Or Even Making A Stop At Signal Light...
sweetles76
Oil In Coolant - 1998 Honda Accord 2.3 Litre V-tec 4...
My Vehicle (with 109,000 Miles On It) Over Heated And I Found Excessive Amounts Of Oil In The Cooling System. I Sought The Advice Of Two...
dickydid
MPV Surges When Hot
My 98 Mpv 4x4 (160k) All-sport Surges Badly While Accelerating When Hot - Either After Running A Couple Of Hours In Cool Weather, Or Much...
HenryW
MAZDA MPV
Interior Door Lights Stay On When All Doors Closed
1996 Sable Sedan; The Other Night I Started My Car And The Door Open Light Was Lit And The Interior Lights Were Still On, So I Went And...
Slim2193
MERCURY SABLE
90 Camry Driveability Issues
Hi, I Have A 90 Camry 4cyl. 235,000 Miles And I'm Having A Driveability Issue. Sometimes While Driving Down The Road My Car Will Cut Out On...
Templer1
2002 KIA Sedona LX Cyclinder Placement
I Need To Know Where The Cyclinders Are Placed On A 2002 Kia Sedona Lx V6 3.6 Litre Engine. If I Stand In Front Of The Vehicle Are The...
rudinski
KIA OTHER
19867
19868
19869
20252
