Toyota 4runner 1995 Blown Head Gasket
1995 4runner, 2wd, 220,000 Miles. I Bought It 8 Months Ago With 200,000 On It From A Donation Yard Where You Pick Out The Car You Want...
J WILLIAMSON
AC Water Leaking Into Passenger Compartment
I Have A 1990 Mazda Miata With 112000 Miles On It. When I Run The Ac After A While The Lower Vents Around The Blower Motor Fill Up With...
Green Machine
MAZDA MIATA
My 1999 Dodge Neon Has 85,000 Miles
My 1999 Dodge Neon Has 85,000 Miles And The Dome Light Won't Go Off And The Door Adjar Light Stays On Yet All The Doors Are Firmly Shut How...
bustercfp
1990 Honda Accord LX Clutch Problems
I Recently Replaced My Select Cable After Having The Clutch R&r'd Even Though I Knew That Wasn't The Problem. Anyway All Of A Sudden I No...
dmag269
VACUM
How Do I Do A Vacum Check On My 1998 Chev Tahoe With A 5.7 V8 Vorted Engine? Where Do I Scew In The Test Gauge? What Should The Vacum Be?
struxgl
CHEVROLET OTHER
Fuel Pump Wont Turn On
I Had Recieved A 1987 Chevy Surban. I Had To Repair The Fuel Tank Because It Had A Leak. I Did Get That Fixed. But I Put Everying All Back...
wfd741
CHEVROLET OTHER
Battery Has A Slow Drain.
I Have A 2002 Yukon Xl With 78,000 Miles. I Have Been Having Problems With The Battery Going Dead After Truck Sits For 4-5 Days. Took...
aqhill
1986 Mercury Sable Steering Knuckle--30536miles
How Do I Remove The Steering Knuckle So I Can Replace The Wheel Bearing/hub Assembly On The Right Side
fire lt
MERCURY SABLE
Burned Up Over Electrical Problems/1988 F150
1988 Ford F150 Lariat 4wd.223000 Kms. This Truck Has Been Very Good Up Until Recently. For What Ever Reason The Battery Started Going...
Doug V
Car Rust
I Drive A 1990 Honda Accord With About 145,000 Miles. Some Rust Has Started To Develop Above The Rear Wheels And On Some Other Areas Of The...
czy4heels
97 Voyager 3.0
I Have A 97 Plymouth Voyager And I Had The Tranny Rebuilt In June Of 05 The Van Has 122500 Miles On It And It Just Recently Started Acting...
loucifer30
PLYMOUTH VOYAGER
1995 Escort Makes Me Pass Out (almost)
Ford Escort Lx 1995 126000 Miles The Car Was Leaking, What Seemed To Me To Be Coolent, But Didn't Fix It. Yes, Typical Female Who...
anootsa
2000 Hondic Civiv 75000 Miler 5 Spd It Wont Start
Honda Wont Start Its Totally Dead. Fuel Good Battery Good Fuel Pump Good. I Will Disconect The Battery And Then Reconected A Few Minutes...
red100
HONDA OTHER
Clutch
I Have A 96 Civic With 245,000 Miles, It Has A Manual Transmission.I Just Had A New Clutch Installed 3 Months Ago. I Have Had No Problems...
mfpicon
2003 Dodge Neon - Noise While Driving - Left Side
2003 Dodge Neon - 80,000 Miles - My Car Is Making A "whirring" Noise When Driving At 20 Mph Or Faster. It Seems To Be Coming From The Left (...
chaberly
2000 Durango - AC Clutch Wiring Issue
I Have A 2000 Durango With 5.2l V8. The Return Side Of The Ac Clutch (black Wire) Shows Very High Resistance To Ground (and The Clutch Won'...
jdearden
White Foam In The Oil Spout
I Have A 1998 Ford F150 Triton V8 With 165,000 Miles On It, I Take Very Good Care Of My Truck And It Runs Great. My Question Is That When...
Charlie2949
Shifter Won't Move Into Gear
I Have A 1994 Honda Del Sol With 150k And Have A Problem Shifting Onto Gear When First Starting Up. I Have Noticed This For About A Month....
rickwood
HONDA DEL SOL
1993 Manual Transmission Problem
I Have A 1993 Honda Accord, Lx W/5 Spd Manual Transm. After Driving For About 30 Minutes The 2nd Gear Grinds Whenever I Shift Into It (...
bjggross
5-series Oxygen Sensor
I Have A 1995 525i. Can Someone Please Tell Me, Where Is The Oxygen Sensor? I Ordered A Replacement Assuming That I Could Find Where It...
jochen19
96 Jetta Oil Blow By? What Dose This Mean?
I Was Getting An Oil Change For My 96 Jetta Gl 2.0 5 Speed 180 000kms. They Siad That There Is Oil Blow Present In The Air Box. What Dose...
koolmike500
1997 Oldmobile Achieva Security System Factory Made
1997 Achieva 11500 Milesthe Security Light Comes On When I Try To Start The Car And It Shut Down. I Have Took It To A Gm Dealer They Can...
queenbee
Steering Wheel Won't Turn
I Have A 1996 Pontiac Grand Am With 108,000 Miles On It And Whenever The Temperature Dips Below Freezing In The Winter, I Have A Very...
danno_mn
1997 Honda Accord
I Have A 1997 Honda Accord With 90000 Miles. The Problem That I Am Having Is That When I Am Driving The Car It Will Shut Off And When I Go...
alex21
Clicking And Vibration
I Have A 97' Gmc Sonoma Extended Cab. It's A 2.2l 4 Cylinder 2wd Manual. It Has 63k On It. I Replaced The Transmission At 55k Due To A...
LitleFiredude49
GMC SONOMA
19866
19867
19868
20252
