1986 Nissan 720 Pickup, Brake Light On Dash Won't Go...
109,000 Miles On My Nissan 720 Pickup. My Truck Won't Pass State Inspection Until The Brake Light Indicator On The Dash Goes Off Correctly...
riddlec
NISSAN TRUCK
Location Of PCV On 540
Where Is The Pcv Located On A '98 540i? Thanks, Radar
Radaruk
1954
BMW OTHER
First Truck
Hello ! I Am About To Buy My First Truck But Im Not Sure Where To Begin. There Is So Much Out There And So Many Rumors About One Type Or...
Northwest
Clutch Problem
My Car Is A 1997 Hyundai Excel Milage 172737 When I Drive Along Changing Gears Usually From 1st To Second The Clutch Just Goes Straight...
higgins
HYUNDAI OTHER
Excessive Surging On Startup/'93 Camaro
Problem Began In The Middle Of Summer At 100 Plus Degree Weather So Surging Was Not In Response To Cold Weather. Surging Would Stop When...
Camaro93
Check Engine Light Keeps Coming On
In My Household We Have A 1998 Saturn, Sl1, Single Overhead. With A Little Over 114000 Kilometres On It. Two Years Ago, The Check...
zipota1
Power Stearing Pump
How Do You Get The Pulley Off The Pump. I Have A 1990 Ford F350 With A 460 Motor With 405,000 Kl. Thank You
dennis murray
FORD F-350
1998 Ford Contour SE Rough Idle/Stalling
I Have A 98 Ford Contour And Recently Since It Has Gotten Colder (40 Degrees And Lower) It Will Start Just Fine But Then It Stalls When...
dh_6783
FORD CONTOUR
Sable Overheats
My 1998 Mercury Sable Quit Heating Last Winter So I Had It Flushed Twice And Backflushed Once. It Never Heated Next Step Was To Take All...
nahcv89
MERCURY SABLE
Transmission
I Have A 1988 Cavalier With A 2.8 Motor And A 5 Speed Tranny With 134,000 Kl. The Problem Is The Shifter Won`t Move Side To Side To Shift...
dennis murray
CHEVROLET OTHER
Car Cranking But Not Starting!
A Couple Of Days Ago I Went Out And Tryed To Start My 1992 Chevrolet 4-wheel Drive 350 V8 74000 Miles Truck And It Kept Cranking But It...
gregorylucas
CHEVROLET OTHER
Overheating And Overcooling
I Have A 1992 Gmc Sierra 1500 Z71 5.7 Liter. In The Summer Time If I Use The A/c Or Tow Anything Much Over 1000 Pounds It Overheats. I...
slothdaddy60
Arcing Noise Passengerside Kick Panel 92 Toy 4x 6cyl
I Have Been From Time To Time For The Last Few Years Been Hearing A Arcing Noise At Or Around The Ecu On The Passenger Side Of My 92 Toyota...
richee
TOYOTA PICKUP
Removing The Alternator On A '94 Probe SE
Hi. My Son Has Ford Probe Se 1994 With 186,000 Kms And A 2.0 Litre 4 Cylinder Engine. The Problem Is The Alternator Needed To Be Replaced....
B Stevenson
FORD PROBE
Fuel To Lean
I Recently Put One Of Those Injector Cleaners In My 2001 Sonata. When I Went To Get The Oil Changed They Also Put One Of Those Injector...
chicago1
HYUNDAI OTHER
2001 GMC Sierra Window Issues
I Have A 2001 Gmc Sierra With ~80k, And Power Windows. Yesterday I Rolled Down My Drivers Side Window And Heard A Crackling Sound. When I...
bigk151
Nothing Working On Dash
Hello, This Is A 1999 Dodge Caravan. There Is Nothing Working On My Dash(fuel, Speedometer Or Temp Gauage)also It Does Not Show Anything...
Davidstjohn
96 VW Jetta - Replaced Oxygen Sensor / Radio...
Mileage 122,000. Just Had One Of My Oxygen Sensors Replaced Last Night. Now My Factory Installed Radio Reads "safe" On The Digital Screen....
mrsjetta
1990 Toyota Camry--cold Start Problem
I Have A 1990 Toyota Camry With 270,000 Miles On It. It Does Not Want To Start When It's Cold Outside. But, It Does Crank And Attempt To...
wheatsix
Won't Crank
I Have A 1981 Buick Regal With A Medium Milege And A 6 Cylinder Engine. It Went Dead While Driving And Now Won't Crank. Good Battery And...
sirralphie1
BUICK REGAL
'03 Olds Alero
I Have An '03 Olds Alero And I Have Found That As The Weather Has Gotten Colder, My Horn Will Blare Uncontrollably At Times When I Start...
Dcapano
Hey All
Just Joined And Wanted To Say Hi! Looks Like A Great Forum With Lots Of Help Topics! Will Talk Soon! Regards, Chris
carundell
1998 Ford Escort Wagon 92k Mil. Surge At Idle
Just Purch. This Vehicle. Serv. Engine Soon Light Is On Solid, Not Flashing. Was Told It Was Due To Low Quality Fuel Or Needed Oil Chg....
Lilybitt
1999 Ford Taurus
Can Someone Tell Me How Long It Takes To Replace A Radiator In A Taurus And How Hard Is It.
copy99
Radio Turns Off When In Gear!!!
I Have A 97 Mercury Sable, Every Time I Put The Car In Gear The Radio Turns Off, Put It In Park It Comes Back On. Can You Help?
BigDaddy22806
MERCURY SABLE
19861
19862
19863
20252
