Dashboard?
CBETHEL65
  • 2008 CHEVROLET SILVERADO
  • 6.6L
  • V8
  • TURBO
  • 4WD
  • 120,000 MILES
I have broken dash when I change dash how do I set proper miladge
Wednesday, December 3rd, 2014 AT 4:04 PM
JOHNNYT73
  • 924 POSTS
You will have to remember your milage and take it to a dealer to program it in. Some that sell or rebuild these units can do it when you order it.
Wednesday, December 3rd, 2014 AT 5:37 PM
CBETHEL65
Thankyou
Thursday, December 4th, 2014 AT 3:25 AM
JOHNNYT73
  • 924 POSTS
Your welcome!
Tuesday, January 27th, 2015 AT 7:02 AM
BOOMER24
  • 2003 CHEVROLET SILVERADO
  • 192,142 MILES
Want to clean dash how do I remove the dash
Friday, July 24th, 2020 AT 6:03 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Dash removal is not an easy job and for the sake of cleaning, I would not want to attempt it as it involves a lot of removal, including disconnecting wireharness etc. If the job is not done correctly, you would likely be causing a lot of unnecessary trouble shooting later.
MIKE SWY
  • 2002 CHEVROLET SILVERADO
  • 119,018 MILES
Dash doesnt work have replaced with gm reman
Does it have power?
MIKE SWY
Yes will light up intermittly
SUSAN.BAER
2002 Chevy Silverado V8 Four Wheel Drive Automatic
I need to replace the dash accessory plugs, how do I remove the old ones?
  • 110,182 POSTS
What plugs are you refering to?
RONGAST
  • 2000 CHEVROLET SILVERADO
  • 300,000 MILES
I need to remove and replace my ignition because it is sticking I do not know how to remove it, do I need to remove the whole dashboard. I don't know what else to ask here because I don't understand any more, could you send me pictures
WRENCHTECH
  • 20,761 POSTS
Here are the instructions to replace the dash in the post below.
JNNELSEN
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 108,000 MILES
I am trying to access the cup holder for removal. I want to be certain I don't break the dash panels. They appear to be held on by a series of screws and clips.
Thanks.
Friday, July 24th, 2020 AT 6:04 PM (Merged)
DR LOOT
  • 2,311 POSTS
Are you talking about the center section of the Dash? Are you trying to install a original original cup holder, or an aftermarket?
JNNELSEN
I am trying to repair or replace the existing factory cup holder. The swingout for the 2nd cup became jammed and I removed it. The cup holder was then stuck 'out'. It got pushed in and is now stuck in. The cup holder will only move in and out about 1 inch. I am trying to access the cup holder track so I can repair or replace it.
Thanks
DR LOOT
  • 2,311 POSTS
That particular dash in the center section snaps together, make sure you remove the glove box door first, so you don't break the little hinge that's connected to the center section, the instrument cluster cover is held on with 4 torx screws
JNNELSEN
Thank you
SOUTHWESTSPORT
  • 1995 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 130,000 MILES
Would like to find out the proper steps for removal and replacement of a complete dashboard? I am removing the complete dash because it is cracked and unserviceable. Also, after being in storage there could and probably is some mouse nests behind which need to be removed?
Monday, July 27th, 2020 AT 10:07 AM (Merged)
Instrument panel assembly replacement
Remove or Disconnect
Negative battery cable(s).
Disable SIR system.
Three relay center bolts from inside wheel opening and set aside.
Bulkhead connector.
Two screws retaining Convenience Center to cowl.
Cruise control harness (if equipped).
Forward lamp harness.
Rear lamp harness.
SIR system harness.
Relay center.
Antenna lead-in.
Steering shaft bolt.
https://www.2carpros.com/forum/automotive_pictures/12900_p1_1.gif
Left and right hinge pillar trim panels.
Brake release handle from the cable.
Clip releases handle from cable.
https://www.2carpros.com/forum/automotive_pictures/12900_p2_1.gif
Four lower bolster screws.
Unsnap bolster.
Twist brake release cable to disengage.
Lap cooler hose.
Reaction plate assembly.
Tie bar.
8-way column connector.
48-way connector retainer to access two lower column nuts.
Shift cable (automatic transmission).
Steering column from the vehicle.
Shift levers.
Transfer case knob by pulling straight up.
Four wheel drive models must be in 4-LO range.
Manual transmission (if equipped).
https://www.2carpros.com/forum/automotive_pictures/12900_p3_1.gif
Left and right lower I/P pivot bolts.
https://www.2carpros.com/forum/automotive_pictures/12900_p4_1.gif
Center support screw.
Three upper I/P support screws.
I/P from the cowl.
Park brake release cable.
Electrical connectors (as necessary).
DERM
HVAC
22-way engine harness
Stoplamp switch
VSS calibrator module
Clutch or Brake release switches
Electronic accelerator (Diesel)
HVAC control cables (if equipped).
I/P from the vehicle.
At this point, I/P removal is complete. Reverse removal process
https://www.2carpros.com/forum/automotive_pictures/12900_p5_2.gif
Cheers
2CP-ARCHIVES
  • 4,540 POSTS
  • 1992 CHEVROLET SILVERADO
  • 154 MILES
Where can I find a replacement dash for my 92 chevy truck. It is too old to buy an OEM one from GM. Is there an aftermarket maker or can I find a USED 92 dash?
