Introduction
5. Back Pressure Gauge: A backpressure gauge can be used by inserting it into the primary oxygen sensor port. Have a helper start the engine and rev it while watching the gauge, the gauge should not exceed 3 PSI, anything higher signals a catalytic converter failure.
6. Vacuum Gauge Rebound Test: Attach a vacuum gauge to a vacuum port on the intake manifold system. You may need to remove the vacuum feed line to the EVAP system or another component temporarily. Start the engine and allow it to idle as you observe the intake vacuum reading which should be between 18 to 22 inches of mercury (inHg). Have a helper snap the throttle, (push down and quickly release), there should be a brief drop in vacuum as the throttle is opened, but it should return to baseline pressure almost instantly, if this reading takes longer than a few seconds to recover the cat is plugged.
7. Partial Clog: Keep the engine at about 2,500 RPM and watch the vacuum gauge, if the reading is low, or continues to drop this is a good indication there is blockage in the converter and replacement is required.
Also See: Symptoms of a Bad Catalytic Converter
False Testing Assumptions
- Unusual Smells: If the exhaust smells like rotten eggs it means the catalytic converter is overworking due to extended heavy engine load.
- Excessive Heat: Check if the exhaust area near the catalytic converter is extremely hot, this is a sign the engine is running rich.
Conclusion
Some vehicles have a primary and secondary catalytic converters to help clean engine exhaust gases. Their locations can vary in the exhaust system depending on the manufacturer. This guide will work for both primary and secondary cats, but the difference in temperature will be more apparent in the primary unit which is closest to the exhaust manifold and more receptive to the chemical reaction due to the additional heat.
Watch the Video!
Please watch this video of the job being done to glean additional helpful information.
Credits
This guide knowledge base was created by the 2CarPros Team, and by Ken Lavacot: Automobile repair shop owner and certified master automobile technician of over 30 years. If you have question or need help please ask the 2CarPros community we are happy to help. Please visit our 2CarPros YouTube Channel for additional car repairs.
