Problem when attempting to accelerate feels like the engine has no power
2004 LINCOLN LS
60,000 MILES • V6 • 2WD • AUTOMATIC
AARONRARE26
So when I'm driving it seems like when your pressing down on the gas pedal the car seems to cut out like no power is getting to the engine.
Sep 29, 2014 at 12:48 PM
  • CAR REPAIR CONTRIBUTOR
Recommend you check the fuel pressure and then check these sensors: MAF, this guide will help us fix it
https://www.2carpros.com/articles/engine-has-low-power-output
Sep 29, 2014 at 1:24 PM
AARONRARE26
Not really good with cars should I take it to mechanic or try and figure it out myself?
Sep 29, 2014 at 7:05 PM
  • 110,190 POSTS
This sounds like an issue with low fuel pressure. It can be the result of a faulty pump or a partially plugged filter. The first thing I would suggest is to check pressure. Here is a link that explains how it is done. You will need a fuel pressure gauge to test, but most parts stores will lend one to you.
Here are the directions specific to your vehicle. The attached pics correlate with the directions. The pics are diagnostic flow charts for issues that are found.
___________________________________
If you look at the attached pic, it shows the manufacturer's specs related to fuel pressure requirements. I highlighted your vehicle.
If you find the pressure is low, I would start by replacing the fuel filter which is mounted on the passenger side inner fender under the hood. Here are directions for lines and fuel filter replacement. The attached pics correlate with the directions.
2004 Lincoln LS V6-3.0L DOHC VIN S
Procedures
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Filter Service and Repair Procedures
PROCEDURES
FUEL LINES AND FUEL FILTER
Disconnect Tool, Spring Lock Coupling
pic 1
SPECIAL TOOL(S)
WARNING:
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
- Fuel in the fuel system remains under high pressure even when the engine is not running. Before repairing or disconnecting any of the fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel, causing personal injury or a fire hazard.
REMOVAL
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Disconnect the battery ground cable.
3. Relieve the fuel system pressure.
4. Remove the left front wheel well rear splash shield.
pic 2
5. To remove individual components, only carry out the listed steps.
pic 3
6. Illustration 1 of 4. Remove the components in the order indicated in the illustration and table.
pic 4
7. Illustration 2 of 4. Remove the components in the order indicated in the illustration and table.
pic 5
8. Illustration 3 of 4. Remove the components in the order indicated in the illustration and table.
pic 6
9. Illustration 4 of 4. Remove the components in the order indicated in the illustration and table.
Item 2: Spring Lock Coupling Removal Note
pic 7
1. Install the special tool.
pic 8
2. Press the special tool into the open end of the cage.
pic 9
3. Separate the spring lock coupling.
INSTALLATION
1. To install, reverse the removal procedure.
_______________________________________________________
If pressure isn't restored after filter replacement, then you need to suspect the pump is bad.
Here are a couple links you may fine helpful:
https://www.2carpros.com/articles/how-a-fuel-pump-works
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
I hope something here is helpful. Let me know if you have other questions or need help.
Apr 17, 2020 at 8:13 PM
FINS228
my engine wont go over 3000rpm throttle body and mass airflow changed..car still sluggish. is there any other items to check
May 23, 2020 at 10:55 AM (Merged)
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
PAT1983
I have a 2003 Lincoln ls with codes po300 po301 po303 also codes po402 and p2272. While trying to accelerate it won't go past 10 MPH and has no acceleration power the car is spark knocking also. Thank you
HMAC300
  • 48,601 POSTS
the first three codes can be a bunchof things, like egr stuck open, cam sensor wheel ijectors etc. 402 is exaust gas system problem. this may be causing your other problems.the last one is either a vacuum leak, injector problem . this should really be checked by a pro because some of these codes may fix others .
JRDOMINQUEZ
I needed a new egr valve so car sat for about 5 months. I got a new egr valve, installed it now got a new code PO443. Also the car has no power in drive but it has full power in reverse. I can burn out in reverse but as soon as I put it in drive nothing. Before I parked it , it ran fine and now it has no power in drive.......also it doesn't rev up while its in park......please help!
  • 110,190 POSTS
Is that the only code you have? It is a EVAP code for the purge control valve circuit. That shouldn't cause any of the conditions you mentioned. It could cause a rough idle or a lean condition for the engine, but that should also set other codes.
Is the battery fully charged? Have you tried disconnecting the battery and then reconnecting it to see if it resets the computer?
GEO8762
Engine just began to overheat so shut it off had thermostat n fluids replaced, now once hits 2250 rpm the engine shimmy's n went to test drive up road won't go past 3000 rpm
  • 54,334 POSTS
Is the check engine light on? see if the the engine will rev in neutral, you could have a cat converter that is plugged, this sometimes happens after the engine have been overheated.
A compression test could tell us if the engine was too badly overheated which should be performed.
We are interested to know what happens please.
JAIRID
  • 8 POSTS
I own a 01 Lincoln ls 3.9. It started with dead fuel pump, and progressed to losing my tail lights and dash cluster. and now i have to power to my head lights. i checked all my fuses and found 8-12 have no power.i checked under the hood and also no power to my pcm. i had a blown fuel pump fuse replaced already. and i also had a blown heated mirror fuse replaced. when i replaced those fuses when i lost all power to my Lincoln. iv been worken on cars for years and im stumped.
Check all the fusible links and test the headlight switch
CADIEMAN
  • 3,544 POSTS
test for voltage at head light bulb as well as the fuseable links by the starter.if the links are good.check the voltage at the dimmer switch harness and it transfers voltage properly.if not you going to have to replace the turn signal switch.
JAIRID
  • 8 POSTS
I did this also. I could not get a reading at all. I forgot to mention that while I was testing the pump the horn went nuts and when u turn the key It was acting like the battery wwas going dead. On currently holding 8.7 volts in the battery from my wife cranking trying to start it while it broke down. I can't get any power at all in the car.
Charge the battery and then load test it-not over 9.6 volts replace it
JAIRID
  • 8 POSTS
I tested it this morning it was 12.8, And still no head lights tail lights horn anything.
CADIEMAN
  • 3,544 POSTS
you need to check the voltage at the headlight switch.start there.
JAIRID
  • 8 POSTS
i checked. i have no voltage. i also have no voltage in the fuse box for the lights. all other fuses has power. when u turn the key it acts like its dead. no lights no turning over nothing. like i never put the key in the ignition. also no power to the ignition. no blown fuse ethier.
JAIRID
  • 8 POSTS
i have no voltage out light switch. but from fuse box in the car i have no power to starter realy coil. radio,any of the head lights 8-11 ddm right front high beam (23), pats system,loft front low beam (25), switch back lighting. under the hood i have no power to head lights at all, fuse box i have no power to fuel injectors and transmission solenoid.Also the plugs connecting to the computer in the car. plug on the left of the fuse box i have no power and some pins on the right of the plug fuse box ether. is the computer in the car bad possible.
CADIEMAN
  • 3,544 POSTS
u check the voltage at the starter.when you turn the key to start position their is no power going to the seliniod or starter?
JAIRID
  • 8 POSTS
Silinoid
JAIRID
  • 8 POSTS
Sorry starter relay coil fuse in the car in the fuse box
CADIEMAN
  • 3,544 POSTS
if you set the pats alarm sys. off the horn and lights will flash and sound and it will not start.untill you reset it.
JAIRID
  • 8 POSTS
How would I test the bcm or pcm
TTHORNSBERRY
I have a 96 lincoln mark 8, with 119k miles I bought
new. I had the 100K tune-up performed on time although I had no problems. Resently the check engine light came on and I could feel a slight roughness in the engine thorugh the steering wheel and a loss of power. When I shift into a higher gear the power loss is evident ie bucks when shifting to a higher gear uphill and normal power is not there. I took it to my repair shop and told them I thought it might be an air sensor. They told me they felt it was the plug wires and I felt that after 10 years what the heck.(No change after wire replacement) This engine has performed very strong for ten years and now feels like a dog. What do you think might be causing this problem? Thanks for letting me ramble!
May 23, 2020 at 10:56 AM (Merged)
CATCH_15
  • 250 POSTS
What all was replace during the tune up? Also, has the car been scanned for trouble codes. It could be the mass air flow sensor. The best thing to do would be to scan for trouble codes and go from there.
