1998 Lincoln Continental
Engine Cooling problem
1998 Lincoln Continental V8 Front Wheel Drive Automatic
My car is leaking coolant between motor and transmission in the area of the flywheel. I would like to know what could be the cause of the leak in that area. Thank You for your time
October 1, 2010.
It's probably not as serious as you think. This engine uses a plastic intake manifold with a valley under it. They have a lot of problems with the intakes leaking. There is also a pipe that runs under the manifold with a rubber hose on the end that can leak also. This valley has a drain hole at the rear that drains right into the bellhousing. Look at the very front of the manifold for a crack. That is a common spot.
You really need to pressure test the cooling system and you will see the leak. Look down behind the alternator.
Oct 1, 2010.
