My Engine cranks over but will not start?
2004 HYUNDAI SANTA FE
160,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
PILOTROB
I can hear the fuel pump running when turning the key, I have spark from the plug wire to ground. I have sprayed starter fluid into the throttle body - nothing. I have checked fuel injector pulse with a noid light. I could also feel fuel pulse in the fuel line at the fuel pump when the car is started. Checked relays and fuses. Replaced all spark plugs (needed it anyway). New battery, plus I tried jump starting it.
Sep 25, 2018 at 3:57 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
If you have proper fuel pressure, spark, and the injectors are working, it does not have a choice but to run. However, since it will not even start with starting fluid indicates a few possibilities. One of the following has to be wrong: weak spark, engine timing, or low engine compression. Does the engine sound normal when it is cranking or does it seem off?
Here is a link that discusses different reasons why engines will not start and ways to check. Some of the items listed will not help because you already did a lot of the work. Regardless, check through it and see if anything helps.
Also, let me know how it sounds when cranking. If you have other questions or need additional information, let me know.
Sep 25, 2018 at 6:55 PM
COWBOYKING1988
My car turns over but will not start. it's a 2004 Hyundai Santa Fe 2.7L v6. I have replace spark plugs and put a new fuel pump in it and it still will not run. I cannot figure it out for nothing. I need help to fix it.
Mar 12, 2019 at 8:16 PM
  • 110,190 POSTS
Welcome back:
If you have spark and tried starting fluid with no results, then either it is a timing issue or low compression. Or, you have a very weak spark. It should be a hot blue snapping spark. Did it even fire a couple times with starting fluid? Also, can you let me know how this issue came to be? Did it happen all at once? If you remove spark plugs, are they wet?
Let me know. Also, it's hard to tell, but it almost sounds like it is cranking really fast. If you brought this to me and it had spark and fuel, the first thing I would check is compression. It almost sounds like timing is an issue and a compression test would indicate that.
Here is a link that shows in general how it is done:
Here are the directions specific to your vehicle with the manufacturer's specs. The attached pictures correlate with these directions.
CHECKING COMPRESSION PRESSURE
1. Before checking the engine compression, check the engine oil level. Also check that the starter motor and battery are all in normal operating condition.
2. Start the engine and wait until the engine coolant temperature reaches 80 - 95°C (176 - 205°F).
3. Stop the engine and disconnect the spark plug cables.
4. Remove the spark plugs.
5. Crank the engine to remove any foreign material in the cylinders.
6. Insert the compression gauge into the spark plug hole.
7. Depress the accelerator pedal to open the throttle fully.
See Picture 1
8. Crank the engine and read the gauge.
Standard value .................... 1,200 kPa (170 psi)
Limit .................... 1,050 kPa (149 psi)
9. Repeat steps 6 to 8 for all cylinders, making sure that the pressure difference for each of the cylinders is within the specified limit.
Limit .................... Max. 100 kPa (14 psi) between cylinders
10. If a cylinder's compression or pressure differential is outside the specification, add a small amount of oil through the spark plug hole, and repeat steps 6 to 9.
1) If the addition of oil causes the compression to rise, it is possible that the piston ring is worn.
2) If the compression remains the same, valve seizure, poor valve seating or a compression leak in the cylinder head gasket are all possible causes.
Tightening torque
Spark plug .................... 20 - 30 Nm (14 - 22 ft. lbs.)
__________________________________
Let me know what you find or if you have other questions. Remember, if you have fuel and spark, either timing or low compression are suspects.
Mar 13, 2019 at 3:54 PM
RACEN2U
If it sets for a while, 18-20 hours, it will not start. Everything works, all light alternator, everything it just wont turn over. I have to turn the key off and wait 20 seconds and try again. It never takes more then three try's to get it started.
Jan 2, 2021 at 9:01 AM (Merged)
OIDAVEY
  • 0 POST
Lets run the codes first it sounds like the engine coolant temperature sensor is shorting out but to be sure lets run down this guide.
and
KRISTENLEE
  • 0 POST
I found out my computer was bad got a rebuilt unit all fixed! Cost me $187.00
DWIGHT1958
  • 6 POSTS
car quit running. won't start back will crank. but no spark or fuel.
Jan 2, 2021 at 9:05 AM (Merged)
Let's start with checking for codes. Then let me know how we found no spark or fuel.
With just this info, the most likely cause is the crank sensor. Here is a guide that will run through this. Let me know the testing you have done so far and if you have a signal coming from the CKP sensor.
JOHN L WILLIAMS
  • 8 POSTS
Brought to me with crank no start. Found the ignition condenser power lead grounded to block.(as in condenser cut off and stake on installed to end of wire). Replaced condenser, but still no fire. Thinking it may have blown the ignition control modual.
  • 54,350 POSTS
Lets start by running the codes.
Please let us know what you find.
Cheers, Ken
JOHN L WILLIAMS
  • 8 POSTS
Will get scanner and run
Jan 2, 2021 at 9:06 AM (Merged)
  • 54,350 POSTS
Cheers, Ken
JOHN L WILLIAMS
  • 8 POSTS
Bought code reader ran it only code that I got was for fuel temp
  • 54,350 POSTS
That will do it. here is the sensor location so you can get it replaced to see what happens. As long as you are there turn the ignition key tot he on position to see if you hear the pump working for about 5 seconds.
It under the back seat under the tap door
Check out the diagrams (Below)
Cheers, Ken
JOHN L WILLIAMS
  • 8 POSTS
Would the fuel temp sencer give me a crank no start
JOHN L WILLIAMS
  • 8 POSTS
Fuel pump is running
  • 54,350 POSTS
Yes it will if it is shorted out. Try unplugging it to see if it runs.
JOHN L WILLIAMS
  • 8 POSTS
Decided to go ahead and replace ICM fixed the crank no start. After it ran cleared codes doing good thanks
JOHN L WILLIAMS
  • 8 POSTS
This started as a starter replacement the camshaft sensor plug and ignition coil condenser were HEAT baked and the condenser lead was grounded. I traced the condenser lead back and it joins with the ignition control module on the power side. It must have burned out the ICM when the condenser lead was grounded
I replaced the ICM. Ignition coil condenser and camshaft position wire plug fixed the crank no start problem
  • 54,350 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
TRAUGHBER4
  • 6 POSTS
I have a 2004 huyndai Santa Fe. The belt tensioner broke on the timing bet. I Found another motor to replace the one i had. All was well then it started stalling, misfiring and dying. I had a mechanic read the codes. Each time it would give me segment timing incorrect which the suggestion was to replace the Crank Position Sensor. I replaced it. Now the car will not start. It will turn over but will not start. I took the new sensor out twice and replaced with another new one. It still wont start. What would be the issue? Do i need to clear the codes or am i haveing a run of bad parts?
SATURNTECH9
  • 30,869 POSTS
What are the exact code numbers you have now?
TRAUGHBER4
  • 6 POSTS
It is a P1372 Segment Timing incorect
SATURNTECH9
  • 30,869 POSTS
So if you clear that code is that the code that comes right back?
TRAUGHBER4
  • 6 POSTS
KHLOW2008
  • 41,814 POSTS
Are you able to restart with the original sensor?
Did you check the pickup point of the sensor for damage?
SATURNTECH9
  • 30,869 POSTS
That's a good one khlow the crank could have struck the sensor.
TRAUGHBER4
  • 6 POSTS
The old sensor was damaged and burned and will not work. The one i replaced it with that would act up after it got warm was returned the parts house. We have checked the contact point on the block to see if there is any obstruction. I have someone coming over today to ome out the wiring harnes to see if there is a broke wire and a voltage probe to make sure were getting the right voltage.
Thanks for all your help.
SATURNTECH9
  • 30,869 POSTS
Alright keep us posted on wat you find.
JARROD L HEINZ
I have the vehicle listed bone. just bought a brand new battery and it turned over once I cut it off started it again and it sputtered and shut off 3 times then went back to not starting at all. what can the problem be?
TRAUGHBER4
  • 6 POSTS
I was mistaken on the code. It was a P0335. It read Crankshaft Possition Sensor. We ran a voltage test and omed it. We are getting fire to the sensor. We are finding we are not getting fire to the coil pack. Would this sensor supply fire to the plugs?
  • 110,190 POSTS
It can be a few different things. However, what you need to do first is determine if there is spark and fuel to the engine. Chances are one will be missing. Once determined, then we will know what system to focus on. If you have a scanner, that would really be helpful. If possible scan for diagnostic trouble codes and let me know what they are.
Now, here is an easy test. See if the engine starts for a couple seconds using starting fluid. If it does, then we know if it a fuel related issue. If it doesn't chances are it is ignition related. If you would rather, here are two links that explain how to check for both spark and fuel:
Check those two things or try the starting fluid and let me know what you find.
SATURNTECH9
  • 30,869 POSTS
It supplies a signal to the coil to fire.The crank sensor should be about 825 ohms.Across one connector terminal of the crank sensor and chassis ground key on engine off you should see 1.4 volts.Then do the same on the other connector terminal and you should see the same.
JARROD L HEINZ
Thank you. I'm going to try the starting fluid when I get off work. but the thing I don't understand is if I jump it off it will start right up but when I cut it off and try to start it back nothing. but thanks for your help. I'll try the starting fluid this afternoon and go from there.
TRAUGHBER4
  • 6 POSTS
Ok, i went back to the same auto parts store and had this one exchanged for warranty. This is the 4th time. I put it on the car and no luck. The car still wouldnt start. I went to another parts house and got a name brand one staying away from house brands. Put the new one on the car and she fired right up. I drove my car to the parts house were i have went through 4 defective parts and told them i wanted to return and no more replacements. They had to ask me if i knew what i was doing and i told them there is the car in the parking lot with a competitors part and it is running. They gave me my money back. I want to thank you for all your help.
James
JARROD L HEINZ
Okay, so when I got off of work I took the new battery back out of the truck and put the old one back in and it started right up. I also bought a code reader and no codes are popping up. this has really got me confused.
SATURNTECH9
  • 30,869 POSTS
Your welcome that's what were here for you could have just checked all those sensors with a ohms meter like I told you could with a ohms meter.That would would have told you that you were getting bad parts all along.
  • 110,190 POSTS
Actually, this most likely will make things easier. First, have the new battery load tested where you got it. If it checks good, then we most likely have a connection issue. Make sure terminals are clean and tight and inspect all wiring around the battery for evidence of damage, corrosion, or anything that can create a poor connection.
Has there been any issues since the old battery was installed?
JARROD L HEINZ
No not at all. since I put the old battery back in its started about 15 times now with no hesitation and it's really cold here this morning and it still started right up.
  • 110,190 POSTS
That's good news. I suspect it was a bad connection. Chances are if it has been good that many times, it should be fine.
If something changes, let me know.
Take care and have a nice holiday.
