Mechanics
PROBLEMS WITH AIR CONDITIONING SYSTEM
2003 Ford Taurus
Air Conditioning problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic 95000 miles
Recently my airconditioning system started pumping out very hot air. When I set the climate control (closed loop control system) it gets hotter as I set it lower. It is not an issue of the airconditioning not funtioning, it is actually sending heated air when it should be calling for air conditioning.
Mtadeg
September 22, 2009.
Have to start by checking if AC system function and if all working as the should
like clutch is engaging on AC compressor when in AC mode
and if so and all working then suspect blend door Or its motor
BMRFIXIT
Sep 22, 2009.
