Mechanics
ENGINE STALLS WHILE AT RED LIGHT IDLE TO
2002 Ford Explorer
Engine Mechanical problem
2002 Ford Explorer V8 Four Wheel Drive Automatic 181000 miles
my 2002 Ford Explorer, stall sometimes when sitting at a red light, it seems to idle too low then dies. Starts fine, runs fine when drivieing but seems to idle a littl on the rough side, it only seems to stall tho when in gear, when it is in park it does not sound to idle right but does not stall.
Dustin111985
October 16, 2009.
We can start testing based on codes first. Are there any present. Cel does not have to be lit.
OR go by symptom.
Does this do this when hot, cold or both?
Any recent repairs (last few thousand miles._ regarding performance?
My explorer only does ths after it warms up, hasnt done it cold yet. The only repair that I have made, about three months ago, was to have the transmission rebuilt. The check engine light is not on either. Thanks
AD
Dustin111985
Oct 17, 2009.
Codes can be set without the check engine light (CEL) on.
I would encourage you to have them checked. Sure they may not show anything, but when they do, it can be one more clue and direction to consider in the diagnosis.
I would suggest cleaning the mass air flow sensor. This is something that could be considered part of today's tune-up.http://www.2carpros.com/how_does_it_work/mass_air_flow_sensor.htm
Also clean the IAC:
http://www.2carpros.com/how_does_it_work/how_an_idle_air_control_iac_works.htm
http://www.2carpros.com/first_things/why_does_my_engine_run_rough.htm
AD
