Crankshaft position sensor location
NIGHTPHOENIX
  • 2003 SATURN VUE
  • 4 CYL
  • AWD
Where is the crankshaft position sensor located in a Saturn Vue 2.2?
Sunday, February 20th, 2011 AT 6:19 PM
Here is a guide and the diagrams below so you can see how the job is done:
Cheers
Sunday, February 20th, 2011 AT 6:27 PM
GRANDMAOFABZ
  • 19 POSTS
  • 2003 SATURN VUE
  • 3.0L
  • V6
  • AWD
  • 178,000 MILES
Recently replaced the crankshaft position sensor and she has been running great. Two days ago the check engine light came on I drove it a total of four blocks. Since then and yesterday she turns over, but will not start. Could it be fouled plugs?
Monday, September 24th, 2018 AT 3:56 PM (Merged)
AL514
  • 4,108 POSTS
You are going to have to find out what the code is that caused the check engine light to come on. The ECM must be scanned and I am willing to bet it will lead you directly to the problem. If you can at least get the code number we can find out its meaning. You can buy scan tools for cheap these days, most auto parts stores sell them less than about eighty dollars.
AL514
  • 4,108 POSTS
Some auto parts will scan the ECM for free if you just ask. Just write down the code number and we will get right on it.
GRANDMAOFABZ
  • 19 POSTS
Does it have to be running to scan?
AL514
  • 4,108 POSTS
Nope, just key in "on" position.
AL514
  • 4,108 POSTS
It is pretty easy, if you buy a scanner it will come with instructions or we can talk you through it. We are always here to help. =)
RENEE L
  • ADMIN
  • 1,257 POSTS
Hi GRANDMAOFABZ,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
FIXIT1000
  • 2003 SATURN VUE
  • 90,000 MILES
Random no start.
  • 31,938 POSTS
There are some automotive electrical testers that claim to be able to test sensors, personally I would not even try, if the system check shows a faulty sensor, 99.9% of the time that is so, if you want to test a used sensor. I would not go there, always use new, but basically in my opinion there is no satisfactory test for this save the scan test.
SATURNTECH9
  • 30,870 POSTS
Just to add to this one you can test the crankshaft position sensor with a multi-meter you just put it on ohms setting of 2,000 most of the sensors will read around 800 ohms when there good. When they test bad they will read as open circuit I have tested many of the Saturn ones. But what you have to keep in mind is you have to test it the moment it fails most of the sensors are bad one minute and good the next. So if it fails long enough and your ready to test it then it can be tested. What size engine do you have? It can also set a code when they fail no always but they can. Have you checked for codes yet?
