HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Pickup
Engine
Symptoms
Backfire
1987 Toyota Pickup
FAMILYPART6
MEMBER
1987 TOYOTA PICKUP
4 CYL
2WD
AUTOMATIC
110,000 MILES
My engine is quietly back firing just a little bit.
Tuesday, January 29th, 2008 AT 5:59 PM
MECHANIC
What kind of fuel system do you have-is it a Carb or an EFI?
Wednesday, January 30th, 2008 AT 1:44 AM
Please
login
or
register
to post a reply.
Related Engine Backfire Content
Backfire
94 Toyota Pick Up V6 Change Plugs Wires Cap Rotor Put Back Together Starts Up Runs Fine But Now Has A Backfire Out Exhaust At Idle Through...
Asked by
fastponti
1994
TOYOTA PICKUP
VIDEO
How To Fix an Engine Backfire
Instructional repair video
GUIDE
Backfire Repair
When your engine backfires it can do so in one of two ways. First and the most common way is when the engine is running a small explosion of unburnt fuel is ignited inside...
Backfires And Dies
If I Can Get My Truck To Start It Will Run Great For Awhile, No Misses Or Pinging But After Awhile When You Down Shift Or Put It In Neutral...
Asked by
maggotchowder
1 ANSWER
1985
TOYOTA PICKUP
1980 Toyota Pickup Backfiring When I Cut The Motor...
I Had Someone Adjust The Carburetor And Noticed Seval Lines Plugged. The Adjuster Guy Said That I Need A Carburetor Rebuild Kit.(Do They...
Asked by
citijean
1 ANSWER
1980
TOYOTA PICKUP
1987 Toyota Pickup Wont Start
I Have A 1987 Toyota Pickup That Wont Star. I Replaced The Battery The Cables And It Started Up Just Fine Ran About 2 Weeks Then Started The...
Asked by
Ironman3005
1987
TOYOTA PICKUP
1987 Toyota Pickup Rough Idle
My Pickup Will Start Fine And Idle Fine At About 650 To 700 Rpms. After I Drive For 5 To 10 Minutes, Or Just Let It Sit And Idle The Rpms...
Asked by
orbit52
1 ANSWER
1987
TOYOTA PICKUP
VIEW MORE
Misfire
Intermittent Misfire
