Torque bolt specs for upper motor mount
JCOROLLA17
  • 2003 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 460,000 MILES
Hi, What are the torque specs for the upper motor mount? Thanks
Do you
have the same problem?
Saturday, June 12th, 2010 AT 9:23 PM
MMPRINCE4000
  • EXPERT
Here are all of the engine mounts torque specs
Engine mounting insulator RH x Transverse engine engine mounting bracket 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting insulator RH x Body 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting member sub-assy center x Body 39 Nm (398 kgf-cm, 29 ft. Lbs.)
Engine mounting insulator RR x Engine mounting bracket RR 87 Nm (887 kgf-cm, 64 ft. Lbs.)
Engine mounting insulator RR x Suspension member 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting insulator FR x Engine mounting bracket FR 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting bracket LH x Transaxle 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting insulator LH x Body Bolt A 52 Nm (530 kgf-cm, 38 ft. Lbs.)
Engine mounting insulator LH x Engine mounting bracket LH Nut B 80 Nm (815 kgf-cm, 59 ft. Lbs.)
Engine mounting bracket FR x Transaxle 64 Nm (652 kgf-cm, 47 ft. Lbs.)
Cheers
Sunday, June 13th, 2010 AT 7:39 AM
Recommended Guides
