Timing belt
GANGSTAFACE00
  • 2004 KIA RIO
  • 4 CYL
  • 148,000 MILES
Just need to know how the timing marks need to be so I can put the new timing belt on. Haynes doesnt make a book for the car and ive been looking everywhere for the diagram.
if the diagram that you have on the site is the wat its suppossed to be then ill just refference that. But I dot know if that is just a diagram or the corect setting. Thank you so much
Monday, January 5th, 2009 AT 5:08 PM
  • 31,937 POSTS
Hi there,
with the timing covers removed, turn the engine over until the cam marks (i) inlet & (E) exhaust are at 12.00 O'Clock they will align with notches on the backing plate, the crank shaft will have a notch & alignment mark & 12.00 O'Clock as well,
mark (mhpautos)
See the diagram below
Monday, January 5th, 2009 AT 6:33 PM
ERIC VANSICKLE
  • 2008 KIA RIO
  • 4 CYL
  • MANUAL
  • 130,000 MILES
What degree should the timing belt be at? 1.6L engine.
Tuesday, April 9th, 2019 AT 5:50 PM (Merged)
HMAC300
  • 48,601 POSTS
If you are talking about replacing belt here are the marks, crank mark will be especially hard to see. See pictures. They should line up to timing marks.
