No spark at the plugs?
JAMSIE119
  • 2004 NISSAN X-TRAIL
  • 70,000 MILES
I have a Nissan x trail that just cut out and now there is no spark at the plugs, ive had it on a Nissan diagnostic machine they changed the accelerator camshaft and crankshaft sensors and that cleared all faults but still no spark checked the timing which was off so changed the timing chain and tensioners. Still no spark there is also no signal at the fuel pump but I have checked it is working
Thursday, June 21st, 2012 AT 2:17 PM
WRENCHTECH
  • 20,758 POSTS
There is a ECM relay that goes out as well on the this car. Here is a guide and some diagrams to help you confirm the problem.
Please let us know what happens so it will help others.
Cheers
Thursday, June 21st, 2012 AT 2:49 PM
JAMSIE119
Checked the ignition coils there is 3 cables at them one has 12v and the other 2 are both nothing. Charged the battery and used a booster pack with it all connections I tried are 12v but still nothing at the fuel pump or spark plugs
Friday, June 22nd, 2012 AT 7:13 PM
KHLOW2008
  • 41,814 POSTS
If vehicle is equipped wit immobilizer, have it checked. If the transponder is not communicating, the starter would be able to crank but engine would not fire up. If you have a spare key, use it to test.
If not equipped with immobilizer, recheck the crankshaft position sensor. Remove it and check the reluctor for damage. Test wire for continuity between the ignition coil and ECM.
Saturday, June 23rd, 2012 AT 3:14 PM
JAMSIE119
I was thinking the immobilizer but not sure if anythin I can do to check it or if I would have to get someone out to do it, when you turn key in ignition the led of dash flashes then goes on steady
Saturday, June 23rd, 2012 AT 5:50 PM
KHLOW2008
  • 41,814 POSTS
The light should go off. That means it is not responding to the immobilizer. A correct scan tool should be able to check it out. As I mentioned, if you have a spare key, try it.
Saturday, June 23rd, 2012 AT 8:16 PM
KRSGT
I have solved the issue with the 2005 Nissan xtrail eng xt40 with no spark if any would like to know it was the ECM relay I installed a new one I am off and running.
I love this site.
Sunday, August 6th, 2017 AT 1:29 PM
LUKETECH AUTO
  • 2005 NISSAN X-TRAIL
  • 2.0L
  • 4 CYL
  • MANUAL
  • 20,000 MILES
Hi guys, out there I am having a problem with my vehicle. When cranking it she wants to take but does not then swings free. Got fuel imob light goes off wen key is on, new sensors.
Monday, August 7th, 2017 AT 3:18 PM (Merged)
HMAC300
  • 48,601 POSTS
Check fuel pressure with gauge auto parts rent it. See link.
scan for codes and check crank sensor fuel pressure should be 51 psi.
HMAC300
  • 48,601 POSTS
Messed up on this one. See pictures for checking power from ECM and coils. Also, check fuses under hood.
KHLOW2008
  • 41,814 POSTS
Did you check for trouble codes?
Check the crank position sensor.
GIFT DONNIE
  • 2007 NISSAN X-TRAIL
  • 2.0L
  • 4 CYL
  • 85,000 MILES
There is no current coming to both the injectors and ignition coils. What could be the possible cause?
Monday, March 25th, 2019 AT 11:42 AM (Merged)
HMAC300
  • 48,601 POSTS
Try resetting your security system if no manual check online. Also check fuses under hood.
