Signal lights
SWEETIE1965
  • 1994 CHEVROLET SILVERADO
  • 4.3L
  • 4 CYL
  • 260,000 MILES
The left turn signal blinks real fast. The right turn signal blinks normal. I have changed both signal light bulbs(front and back) and I have changed the circuit board. All other lights work properly as far as I can see. This has me puzzled? I can hear the flasher come on when signal is turned on. Front and rear signal blink at same time when powered on. What can cause this?
Friday, September 21st, 2018 AT 12:57 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Quick question. Have you by chance converted any bulbs to LED?
Thanks for using 2CarPros.
Danny-
Friday, September 21st, 2018 AT 1:11 PM
SWEETIE1965
  • 157 POSTS
No, I have not converted any bulbs at all.
Friday, September 21st, 2018 AT 1:15 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, on the affected side I would check all the grounds. Hope this helps and thanks for using 2CarPros.
Danny-
Friday, September 21st, 2018 AT 1:48 PM
SWEETIE1965
  • 157 POSTS
  • 4.3L
  • V6
  • 255,000 MILES
I have changed front and rear signal bulb and the circuit board. I can hear the flasher come on when signal is turned on. What can be doing this? Both sides of signal lights blink together when turned on.
Saturday, September 22nd, 2018 AT 11:58 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
You are losing a ground or power somewhere. Here are the blinker wiring diagrams so you can test each circuit using the guide from above that Danny provided. Check out the diagrams (below). Please let us know what happens.
Cheers, Ken
Saturday, September 22nd, 2018 AT 12:09 PM
SWEETIE1965
  • 157 POSTS
The transmission started shifting hard from first gear to second gear. All the rest shift smoothly like it always has done.
Monday, September 24th, 2018 AT 1:30 PM
KEN L
  • 42,904 POSTS
Did you ever get the problem fixed?
Please post your new question here, you must be logged in.
Cheers, Ken
Tuesday, September 25th, 2018 AT 9:46 AM
