Fuel injector
HOWDOIFIXMYSATURN
  • 1995 SATURN SL2
How do I remove and replace the fuel injector in my car?
Saturday, January 30th, 2010 AT 5:22 PM
Here is a guide to help you see what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Here is what the book says:
FUEL INJECTOR ASSEMBLY REMOVAL
WARNING: do not allow smoking or the use of open flames in the area where work on the fuel system is taking place. Anytime the fuel system is being worked on, disconnect the negative battery cable, except for those tests where battery voltage is required.
NOTE: Use care in removing fuel injectors to prevent damage to the electrical connector pins on the fuel injector and the nozzle. The fuel injector is serviced as a complete assembly only. Since it is an electrical component, it should not be immersed in any type of cleaner. Support the fuel rail to avoid damaging other components while removing the fuel injector.
1.Remove fuel rail.
https://www.2carpros.com/forum/automotive_pictures/12900_fi1_2.gif
2.Slide fuel injector retainer clip off fuel injector.
NOTE: Clean the fuel rail prior to removing the fuel injector.
Fuel Injector Retainer And O-ring
https://www.2carpros.com/forum/automotive_pictures/12900_fi2_2.gif
3.Remove port fuel injector assembly and plug the fuel injector port with a clean shop towel
NOTE: Any time the fuel system is opened for service, the 0-ring seals used with related components must be replaced.
4.Remove fuel injector 0-rings and discard.
INSTALLATION
https://www.2carpros.com/forum/automotive_pictures/12900_fi3_2.gif
NOTE: D0HC (LLO) and S0HC (L24) fuel injectors are not interchangeable. Verify that the correct fuel injectors are installed in the fuel rail. The fuel injectors are identified by a color coded plastic ring located near the bottom of the fuel injector. The D0HC (LLO) fuel injector is identified by a pink 0-ring that mates to the intake manifold.
https://www.2carpros.com/forum/automotive_pictures/12900_fi4_2.gif
1.Lubricate new fuel injector 0-ring seals with clean engine oil and install on fuel injector assembly.
2.Install clip onto injector prior to installing injector to fuel rail.
3.Install port fuel injector assembly into fuel rail, with fuel injector's electrical connector facing upward.
4.Install fuel rail assembly.
Here are more diagrams below.
Cheers
Saturday, January 30th, 2010 AT 6:54 PM
LYNNSSSOKC
  • 1998 SATURN SL2
1998 Saturn SL2 six cylinder two wheel drive automatic.
How do I change out my injectors?
My car will not start.
Wednesday, April 18th, 2018 AT 2:01 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
How do you know if you have bad injectors?
Louie
