Cooling fan does not work
PIXTURMAN
  • 2015 CHRYSLER TOWN AND COUNTRY
  • 3.6L
  • 101,000 MILES
The high fan doesn't work. I replaced the radiator fan fuse and it worked for a day. The fuse is no other blown and the low fan works. Is there a high radiator fan relay and if there is, where is it located?
Tuesday, October 22nd, 2019 AT 9:49 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,047 POSTS
There is a high speed relay the TIPM controls it. Here is a cooling fan wiring diagrams so you can see how the system works plus instructions on how to replace the TIPM below. The TIPM replacement is easy because it self initializes. Check out the diagrams (below). Please let us know what happens.
Wednesday, October 23rd, 2019 AT 11:57 AM
PIXTURMAN
  • 5 POSTS
Would a bad TIPM be the the problem if only the hi cooling fan doesn't work? I would think that more than one thing would not be working?
Wednesday, October 23rd, 2019 AT 2:31 PM
KEN L
  • 43,047 POSTS
The TIPM controls the operation of both relays. Have you tested the high speed relay? Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response. Here is the relay location. Check out the diagrams (below). Please let us know what happens.
Thursday, October 24th, 2019 AT 10:13 AM
PIXTURMAN
  • 5 POSTS
You said in the answer to my first question that there was no high speed relay? No I haven't tested it. Now that I know there's one I will test it. The low fan comes on when the engine gets hot.
Thursday, October 24th, 2019 AT 10:37 AM
KEN L
  • 43,047 POSTS
My bad, I didnt look closely at the wiring diagrams. Please let me know.
Thursday, October 24th, 2019 AT 11:47 AM
PIXTURMAN
  • 5 POSTS
I replaced the hi fan relay and the hi fan still doesn't come on. I noticed there's 2 relays so I swapped relays to see if the other one was bad. Still didn't work. Is it possible both relays run the hi fan and both went bad? Is it possible there's something with the AC that that would keep the hi fan from coming on? The lo fan will come on when the AC is turned on but the AC works when the lo fan is on but not when the lo fan is off.
Friday, October 25th, 2019 AT 2:20 PM
KEN L
  • 43,047 POSTS
Thanks for the video. The brown and light blue wire going to the high speed fan relay must ground to get the hi fan to turn on. This is controlled by the TIPM. The brown and orange wire must have power.
and
Please run down these guides and report back. It sounds like the TIPM is out which is common.
Saturday, October 26th, 2019 AT 12:17 PM
RICK DANIEL
  • 2010 CHRYSLER TOWN AND COUNTRY
  • 3.8L
  • 6 CYL
  • 172,000 MILES
Will only come on when AC is on.
Monday, December 21st, 2020 AT 9:47 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This looks like it could be a problem with the Totally Integrated Control Module. It is on the left side of the engine compartment and it contains Radiator Low Speed Fan Relay, Low Speed Signal, Hi Speed Control, Connector Area Bus Inputs, and fused power. In the diagrams down below I have included factory diagnostic tests for both the cooling system as well the Electronic Coolant Temperature sensor (ECT), and the Totally Integrated Control Module. Please go through these tests and get back to us with what you find out.
Thanks,
Alex
2CarPros
HAPPYJOSE
  • 2006 CHRYSLER TOWN AND COUNTRY
  • 95,000 MILES
First the fan fuse blew - I replaced it. Then the passenger side fan smoked; I mean it - there was so much smoke I couldn't see. Pulled the fuse so I could get home. Disabled the fan by disconnecting the cable to the fan motor and replaced the fuse. Ran it that way till the following week when the replacement fan assembly came in. But in the meantime the cel came on - a P0480 code. Cooling fan 1 control circuit malfunction. I replaced the fan assembly but the cel light is still on, and the fans are still not functioning. I thought the cooling fan relay might be bad but I'm having difficulty testing it without a wiring diagram to help me.
The 2 larger wires, say connected to pins 1 and 2 at the relay, I'm assuming provide the power to the fans. And the 2 smaller wires, pins 3 and 4, would be from the PCM to turn the relay on. With the connector off the relay I looked for any signals on pin 3 and 4 with the car running and the air conditioning turned on, but there wasn't any. So I am at a loss on how to proceed. My questions are primarily how should I proceed from here; are there any wiring diagrams available online I could avail myself of [without spending an arm and a leg]; where can I find the PCM module on this model car so I can test the wires and connectors from the pcm and the fan relay?
Any help would be greatly appreciated.
Monday, December 21st, 2020 AT 9:48 AM (Merged)
HMAC300
  • 48,601 POSTS
Here is pic of diagram but be aware that there was a tsb for this code. It required reflashing computer as well as a new replacement part. So that may be part of your problem as well.
HAPPYJOSE
Hmac300 - thanks so much for the wiring diagram - that will help a lot. I read about the tsb regarding the reflash of the pcm. I have to admit though, if it was a software/firmware issue, I don't understand why this problem wouldn't have existed right from the git-go.
Kudos to you - appreciate the info.
HMAC300
  • 48,601 POSTS
There was a newer replacement part involved inthis as well as reflash so if you don't have the part installed it may be that as well.
NYCHAVEZ
  • 3.3L
  • V6
Why wont the cooling fans turn on if I replaced theromostate and the sensor?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first think I suggest you should check is the radiator fans fuse in the under hood integrated power module fuse box. It is on the left side of the engine compartment. The fuse is located in the space #27. Here is a tutorial showing how to check a fuse:
If the fuse checks good then I would check the fan relay. Here is a tutorial showing how to test a relay:
I've attached pictures below of the locations of the fuse which is circled in red and and the relay including how to replace on your van. Hope this helps and thanks for using 2CarPros.
MADHATTER503
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 3.3L
  • V6
  • 126,000 MILES
With the temperature still in the low twenties, it is not am issue now, but when the spring gets here I will need it to work! Relay was tested, fuse good, but fan will not engage, even with A/C on. I jumped the fans and they work fine. Dealer said bad PCM or wiring issue as they changed temperature sensor to no avail. Any suggestions would be appreciated.
OBXAUTOMEDIC
  • 3,711 POSTS
Okay, who tested the Relay? In my experience with that relay I have not been able to accurately test it and have replace to find that it was bad. And I take it the relay tested was located at the front frame rail on driver side.
Now with the fuse, was it tested with a meter or just looked at? I have found with just looking at them it is hard to tell if it is blown or not.
Also, is or was your engine light on? If it is now or was on and still is would have codes pulled. Could be that the coolant sensor that was replaced is defective, does not happen often but it does happen.
Note : A bad sensor will turn engine light on. A bad relay in most cases will not.
I have attached diagrams.
Fuse #27 is the 40 amp radiator fan.
MADHATTER503
Thank you for your quick response. First, my mechanic removed the front grill to access the relay. He plugged a tool into a wire harness that tested the circuit and stated that the fuse and relay were working. Not sure how fuse was tested but I have a multi-meter and can check. "check engine" light is on. Have not replaced sensor, but took it to dealer who said PCM or bad wire. I will check fuse, but I believe my mechanic said that there was power to relay. The A/C should trigger a fan regardless if the sensor is bad? Can an issue with the A/C circuit cause the problem? Thanks again.
OBXAUTOMEDIC
  • 3,711 POSTS
Okay, no the A/C will not trigger fan with bad relay. The temperature sensor signals the relay to trigger the fan/s.
You said he connect to the wiring harness of the sensor, do you know if it also connected to the relay? If just connected to wiring harness then he just check to see if harness was good and getting power, so yes the fuse is most likely good but if did not connect to relay how can he say it is good.
Okay, can you take it to an auto parts store and have them read codes? Right it/them down and post please.
And to be honest if you go into a shop or dealer and they can tell you do not have a clue or do not know much about vehicle they will rip you off. That is why I work for myself with no employees, I am a Mobile Mechanic.
ALLEN WOOD
  • 6 POSTS
  • 3.8L
  • V6
  • FWD
  • 190,000 MILES
My van fans wont run unless you unplug the coolant temperature sensor. Here is what I have done so far:
Replaced relay behind bumper.
Checked all other fuses and relays.
Replaced coolant temperature sensor twice.
Replaced pressure transducer.
I have checked all wires at relay. I have power, ground and signal.
The fans will run when I jump the relay harness.
The fans will run when you unplug the coolant temperature sensor.
The fans will not run when AC is on.
The fans will not run when the engine reaches the temperature in which the fans should turn on.
Help!
