Transmission not shifting properly, speedometer acts erratic
SRESOR83
  • 2002 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 120,000 MILES
Out of no where, the speedometer started going crazy and the car is not shifting right, the cruise quit working and the car just keeps reving up and not shifting when it is supposed too. Also the turn signal clicking noise keeps coming on and clicking really fast. Not sure if any connection with that.
Tuesday, March 25th, 2014 AT 10:44 AM
JDL
  • 16,098 POSTS
As far as the speedometer and shifting, I'd check the vehicle speed sensor. Check for applicable trouble codes. Some of the national brand auto stores will check codes for free.
Do all your turn signals work?
Tuesday, March 25th, 2014 AT 1:06 PM
KIM H1963
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 13,000 MILES
Car won't shift out of 2nd into 3rd. Where would we find the shift sensor?
Saturday, April 11th, 2020 AT 5:20 PM (Merged)
BILLYMAC
  • 2,204 POSTS
Hi Kim, most likely the computer. There are no sensors on the external of this transmission you can change. Billymac
KIM H1963
How about a electric shift? A friend of ours told us there was a electric shift. He doesnt' live close to us, we don't know where to locate this.
BILLYMAC
  • 2,204 POSTS
Hi Kim. Well there is a couple electric shift solenoids. But they are located inside the valve body. Which is an internal part. But you should have car scanned to see if these are bad.
  • 108,269 POSTS
There are many different thing that can cause a problem with shifting. However, since it is limited to second to third gear, I feel it is likely a shift solenoid.
If you look at the attached pic, it shows the locations of the shift solenoids. In pic 2, I have provided a pic specific to the 2-3 shift solenoid. That is the one that should be replaced. When you remove the solenoid, there will be a shift valve, spring, and O-ring. Make sure the o-ring is in good condition and not damaged.
If you decide to replace the solenoid, you will need to drain the transmission fluid, remove the oil pan and filter, and then you will have access to the solenoids.
Here are the directions for replacement of the filter and fluid.
_____________________________________________
2000 Pontiac Grand AM L4-144 2.4L DOHC VIN T SFI
Oil Filter and Seal Replacement
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Service and Repair Removal and Replacement 4T40-E/4T45-E Automatic Transaxle On-Vehicle Service Oil Filter and Seal Replacement
OIL FILTER AND SEAL REPLACEMENT
Removal Procedure
- Tools Required:
- J 6125-1B Slide Hammer
- J 23129 Axle Boot Remover
Caution: Refer to Vehicle Lifting Caution in Service Precautions.
Pic 3
1. Raise and support the vehicle.
2. Place the drain pan under the transaxle oil pan.
Notice: When removing the oil pan bolts, be careful not to damage the oil pan sealing surfaces. Such damage may result in oil leaks in this area.
3. Remove the oil pan bolts from only the front and the sides.
4. Loosen the rear oil pan bolts about 4 turns.
5. Lightly tap the oil pan with a rubber mallet or pry in order to allow the fluid to drain.
6. Inspect the fluid color.
Pic 4
7. Remove the remaining oil pan bolts.
Pic 5
8. Remove the oil pan.
Pic 6
9. Remove the oil pan gasket.
Pic 7
10. Remove the oil filter. Use a long screwdriver in order to pry the oil filter neck out of the seal.
11. Check the oil filter seal for damage or wear.
12. As needed, remove the seal using the J 6125-1B and the J 23129.
Installation Procedure
pic 8
1. Install a new seal, as needed. Before installing, coat the new seal with a small amount of J 36850 or petroleum jelly.
2. Install a new filter into the case.
Pic 9
3. Install the oil pan gasket. Use a new gasket if the sealing ribs are damaged.
4. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
5. Install the oil pan.
Pic 10
6. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
7. Install the oil pan.
Notice: Refer to Fastener Notice in Service Precautions.
8. Install the oil pan bolts.
Tighten
Tighten the bolts to 16 Nm (12 ft. Lbs.).
9. Lower the vehicle.
10. Fill the transaxle to the proper level with DEXRON(R) III fluid or the equivalent. Refer to Fluid Capacity Specifications.
11. Inspect the pan for leaks. Recheck the transmission fluid level. Refer to Transmission Fluid Checking Procedure.
Here are the directions for the oil feed pipe replacement in the trans. Make sure they are tight and the o-rings are good as well.
Oil Feed Pipes Replacement
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Valve Body Service and Repair Procedures 4T40-E/4T45-E Automatic Transaxle Oil Feed Pipes Replacement
OIL FEED PIPES REPLACEMENT
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Service Precautions.
Pic 11
1. Disconnect the negative battery cable.
2. Raise the vehicle. Support the vehicle. Refer to Vehicle Lifting.
3. Remove the transmission oil pan. Refer to Oil Pan Replacement.
4. Remove the transmission oil filter assembly. Refer to Oil Filter and Seal Replacement.
5. Remove the oil feed pipe bolts.
6. Inspect the eight oil feed pipe seal rings.
7. Replace the seal rings only if the seal rings are cut, swollen or damaged.
Pic 12
8. Remove the low and the reverse band oil pipe assembly.
9. Remove the eight low and the reverse band oil pipe assembly seals.
10. Inspect the oil feed pipes for plugged passages, bent pipes, or cracks.
11. Inspect the oil feed pipe seal rings. Verify the proper location of the seal rings. Replace the seal rings if these are cut, swelled or damaged.
pic 13
1. Install the eight low and the reverse band oil pipe assembly seals.
2. Install the low and the reverse band oil feed pipe assembly onto the transmission.
Pic 14
3. Hand start the bolts that attach the oil feed pipe assembly to the transmission.
Tighten
Tighten the bolts to 12 Nm (106 inch lbs.).
4. Install the transmission oil filter assembly. Refer to Oil Filter and Seal Replacement.
5. Install the transmission oil pan and gasket. Refer to Oil Filter and Seal Replacement.
6. Lower the vehicle.
7. Refill the transmission to the proper level.
8. Inspect the transmission oil level. Refer to Transmission Fluid Checking Procedure.
___________________________________-
MCDAVIDHOME
  • 4 CYL
  • 167,000 MILES
My car wont change into overdrive sometimes and when it finally does it wont stay in overdrive. It well down shift back into 3rd and then back into over drive. What could be possibly causing this and does this mean my transmission is fixing to go out?
Saturday, April 11th, 2020 AT 5:22 PM (Merged)
MMPRINCE4000
  • 8,549 POSTS
Generally on GM cars the car must be in closed loop, coolant temp. At operating temp, O2 sensor at specific temperature, car above certain speed etc. So a bad thermostat or coolant temp sensor could be the cause.
It could be a brake switch, which would prevent the OD from working.
I would have the car scanned in live data to see if it is in closed loop, otherwise it could be a lockup solenoid or connection to it. I don't believe you have to remove the trans. To replace the lockup solenoid.
Also check any vacuum lines going to trans. For cracks/leaks.
MCDAVIDHOME
Hey Thanks a lot. You were a great help!
